-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   plugging lower pickups (https://www.offshoreonly.com/forums/baja/321559-plugging-lower-pickups.html)
Taube 12-31-2014 07:55 AM
Read on a thread people have plugged lower pick ups, I'm assuming also called high speed pick ups and shaped the bullet to get 1 - 2 mph at wot.. true?
tmmii 12-31-2014 10:29 AM
I did on mine to help lower water pressure. Mercury makes a kit that is basically 4 set screws and all you do I tap the drive and screw them in.
Unlimited jd 12-31-2014 10:30 AM
The lower or the upper holes? I'd think the uppers closer to the surface.
