-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   33 outlaw questions (https://www.offshoreonly.com/forums/baja/322808-33-outlaw-questions.html)
kennyo 02-05-2015 02:02 PM
33 outlaw questions
I've got 500hp's in my boat that run fine. Barring any engine mods what would be the next bang for the buck modification??? It's a 99 model.
F-2 Speedy 02-05-2015 02:16 PM
If you looking for increased speed, 6-7 grand should get you some shorties, those drives are deep, it get expensive chasing 2-3 mph
Keith Atlanta 02-05-2015 02:25 PM
Why not the top end mods for your 500's? Probably the cheapest considering 2 shorties will be $6000 by the time its all said and done...
There is thread from 2-3 months ago about shorties on a 33 or shorties and extension boxes on a 33. I personally dont think just shorties will do anything great, you will need boxes too. That was the topic of the mentioned thread.
Shorties did nothing for me, raised drives with boxes did and increased ride/handling.
nailit 02-05-2015 07:12 PM
would taking out the lil hook in the back actually gain anything? mine is about 1/4" at the last foot near the transom.
Did ya'll do that to yall 33's.. I know Kevin (offshoreexcursion) did, but dont think I asked him that specific question before. Since it acts like a tab, seems like you could gain 1-2 with that??
F-2 Speedy 02-05-2015 07:32 PM
its expensive to blue print & fix the bottom, if done right, I would think your money would be better spent in raising the drives, up and out like Keith mentioned, I've never ever checked the bottom of mine, low 80's is fine with me
Keith Atlanta 02-05-2015 07:43 PM
I have had a 6 foot level all over the bottom of my boat and strakes and didnt see anything more than .030 I didnt have any hook that I could see.
nailit 02-05-2015 11:08 PM
so what will "blueprinting" or straightening the hull net you in speed?? anyone do just this and what net gains??
JaayTeee 02-06-2015 12:35 PM
Slippery engine oil, drive oil, get the weight out, ( mainly in the front) sharpening the back edge of the hull and fiddling with the props....any more and it gets spendy
Diamond Dave 02-06-2015 01:05 PM
^Slippery engine and drive oil recommendations?
JaayTeee 02-06-2015 04:45 PM
Amsoil...I ran 15W40 marine/diesel and 75w/90 marine gear lube in my HP500's and it netted approx. 200 rpms.
Smitty 02-07-2015 10:23 PM
Shorties alone will not work unless you use extension boxes. Take out as much weight as you can as JT said. Get your props blueprinted. In order to increase speed on a Baja you need to get the bow up high. And I assume you have carbed 500's ?? If you have EFI motors you can get a re flash to get some power and bump the rev limiters so you can work prop pitch as well.
kennyo 02-09-2015 07:23 AM
Dang!
nailit 02-09-2015 09:05 PM
Ok.. maybe I was on crack, but I used a 3ft level and there was only a (maybe) 32nd" if any hook.. I didnt have a 6ft straight edge, but wouldnt any hook at least be in the last 3ft? I must have been think of my 99 25ol having a gap (hook).
