-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Overall Trailer Width (https://www.offshoreonly.com/forums/baja/326768-overall-trailer-width.html)
jetskidrewski 05-30-2015 09:21 AM
Hey 30'+ Baja guys I'm thinking ahead (maybe way ahead) on a garage addition. What is the overall width of your trailer (unless the boat sticks out)? Height is not a concern just width, will 9' doors be very tight but cover most Baja models (29, 30, 33, 35, 342, 38 Special) on the trailer?
Smitty 05-30-2015 07:08 PM
I will measure the width for you tomorrow. You will need a 10 ft door minimum height. A 9 ft will hit the seats on a 33or 36.
jvthundercat 05-31-2015 07:49 AM
My 38 Special takes 9' 2" and have to have at least 10' to clear the top.
We are putting up a 40 x 80 this year and I am going to do a 14 x 10 doors on each end.
Fitting it in a 10 ft wide and having it perfectly straight are two different things depending on how much room you have in front of the building.
Ever heard of the saying "40 acres to turn around" ? Well pulling one of these with a crew cab dually will get you there......
Sydwayz 05-31-2015 07:59 AM
Do not go with less than a 10' wide door. Most boats alone are 8'6" wide. That leaves you 3" to spare on each side on a 9' wide door. The trailer is typically not wider than the boat.
I have 12' wide doors and depending on where I am trying to put my boat in the building, (sometimes I try tuck the boat right up next to the wall) my dually fenders get in the way.
Steel Outlawed 05-31-2015 08:57 AM
I have a 33 Outlaw and Manning welded aluminum trailer with a 10' x 10' door. That will be the minimum you would want to use. I have about 8" on each side and maybe 4" of height clearance. Keep in mind the Manning all welded trailer is a little taller than a lot of the manufacturers.
92nsx 06-01-2015 07:42 AM
Im in the process of building my detached boat garage.
Go with a 10' TALL door, and as wide as you can( I would say a min of 12' ). My garage door is going to be 10' tall X 16' wide. I even passed on a FREE 2 year old insulated door because it was only 14' wide. I want all the room in the world. Old saying says, Go big or go home.
To anster yo question, my trailer like 95% of trailers out there is 8'6" wide. DOT limit with out permit. Majority of the performance boats will be 8'3" - 8'6" wide.
How ever some boats might be a touch wider and push the limits with DOT,. IIRC isnt a 35 or 38, Donzi 9'3" wide?
Sydwayz 06-01-2015 01:03 PM
Yep, 33 and 38 Donzi ZX models are over 9' wide.
puzzleboy 06-01-2015 01:48 PM
So is a 38 Special.
Quinlan 06-01-2015 03:59 PM
12 wide and 14 tall. never know when you need to back in a Coach or maybe a CC with a hard top. Or the person you sell the place too will.
92nsx 06-02-2015 03:14 PM
14 tall!!! Maybe if you live on a farm. Most cities have limits/ covidence about height. For instance to the mid point of my roof, has to be under 14' and still meet what ever the snow load rating is. Dont want to be like NY this passed winter and having roofs fall in. It was a stretchfor me to get 10' tall door.
F##k the next guy :) Build it to fit your needs, LOL!!!
ChaseO 06-03-2015 11:15 AM
The bigger the better. The last thing you want to do is sweat bullets backing your trailer in after a long day on the water.
