Looking at a 232..
This is my first post as a member of OSO. Please forgive me if I am not following proper protocol. I've owned smaller Jet Boats (mostly Sea Doo) in the past and figured it was time to move on to something that I can get 3-4 passengers on it comfortably and maybe take a nap in the stabbin' cabin.
I have had my eyes on a couple boats recently. Originally was interested in a 90s 24 Outlaw, later on I found a pristine (appearance) condition 1998 232 Performance. As part of due diligence I took it for a sea trial and found it to handle mid-30ft cruiser wakes well. Owner claims to rarely use the tabs and it comes onto plane quickly with minor bow rise. Top speed with full fuel and two passengers (estimated people weight 500pounds) was 50mph on gauge @ 4600RPM on gauge (slightly trimmed, I wasn't driving or I would have brought it up a bit more). About the boat: 7.4 MPI 600ish hours on the hour meter, owner claims that his mechanic left the key on this spring during de-winterization which ran up approximately 120 hours Bravo 1 (1.5 gear ratio, one year old - new style graphics, 1 year old, owner claims it was $7500 in all) 4-blade prop in terrific condition (20 or 21p aluminum I think?) - comes with two additional props (one stainless, both 3-blade) with higher pitch. One of the spares looks a bit chewed on. Didn't look too closely. Single-ram Trim Tabs Newer radio, alpine speakers Matched paint trailer in great condition All original vinyl, no tears or loose seams and no fade Drop-out bolsters Dual batteries with switch Faded/yellowed glove box hatch Brand new boat/trailer cover, has snaps for cockpit/mooring cover but is missing Very smooth hull - smooth center line I'm pretty sure if it was rarely ever beached. No signs of fiberglass repair. Bilge/engine compartment vents on side of boat (plastic) showing UV-fade Transom, motor mounts appear to be strong - motor doesn't vibrate or cause any flex when underway Steering at the wheel has approximate 10-degree slop and the owner claims his mechanic has looked into it and short of adding hydraulic steering is functionally normal. Doesn't seem to be as much of an issue on plane. Anyway, I'm prepared to make an offer on this boat as the fiberglass appears to be in remarkable condition for its age. Is there anything that anyone can suggest I inspect before making this deal happen? |
Check hop around on the floor in a few spots to make sure there are no soft spots.
Trim the engine down, stand on the cav plate on the drive and bounce on it a couple times...should be no movement of the transom assembly (checking for soft transom). The steering is pretty normal on an older bravo boat with no external hydro steering Pick up on the drive and wiggle it around to check for slop in the hinge pins Have his mechanic scan the engine for you to verify his claim of 480ish hours. The ecu will only log hours that the engine is running, unlike the hour-meter at the helm. Did it take on any water during the sea trial? If so, it could be coming from a multitude of places, some more expensive to fix than others. Those are a few off the top of my head. |
Thanks for your response.
Bilge was as dry after we put it back on the trailer after an hour of running or so - a little residual oil that was there from the oil change as the oil filter is mounted facing down. Figured if I were selling a boat I'd have cleaned all of that up before showing it to anyone. I didn't pull up the carpet but it seemed like there was a slight soft spot where the fuel tank access panel is, or whatever that access is between the captain and co-pilot's bolster seats. Not a large amount of flex, might be normal for a 300-pound guy like me. I'm sending my mechanic there tonight to look at the drive and strength of the transom. I don't think he'll bring a scan tool and even though I shouldn't trust the owner about this (and he says I don't have to) I'm leaning in his favor. |
I would make sure he takes a scan tool for sure. The ol' 7.4 truck motor will run great a long time with regular maintenance and NO MODS.
The bulkheads and stringers at the transom need to be checked close for signs of wet/rot. Pull the stainless vents out of the cabin floor and have a look see in there for trapped water. That's a potential BIG PROBLEM and a costly one. The deck plate between the bolsters (tank inspection/access) will flex especially if you're 300 pounds but the rest should be firm.Great boats for what they are. Good luck man. |
Going on 3 years in our 232 and we love it. It's been a great boat for Lk. St. Clair even though it can get rough here and there. I'm happy to share thoughts on other specifics as well...
I don't have any vents in the floor of the cuddy, however the step comes up by removing 4 screws (they are hidden within the carpet, tap to find them). Our 6.2 gets to 58mph GPS with a 22p 4-blade or 21p 3-blade. |
With the right prop, speeds will be in the upper 50 range.
Originally Posted by jetskidrewski
(Post 4454417)
I don't have any vents in the floor of the cuddy, however the step comes up by removing 4 screws (they are hidden within the carpet, tap to find them). Our 6.2 gets to 58mph GPS with a 22p 4-blade or 21p 3-blade. What year is yours? Which exhaust? What do you do for a cover? |
2002
Silent choice exhaust. (non-switchable) Have a cockpit cover that snaps down over the windshield. And until last weekend had a trailering cover. It came loose, tore, and the ratchet strap chipped up the swim platform. Not sure I'd recommend that type of cover, but I'm not sure if it was operator error. Both require a single pole in the center of the cockpit. |
I picked up the 232 last night. Did a complete wash on her right after this, but it's a pretty clean boat already. Probably will need new carpet eventually, here's a photo with the former owner's registration numbers blurred: http://i.imgur.com/VYZLCgY.jpg
Very nice, I like those graphics a lot. Where will you be boating?
| All times are GMT -5. The time now is 07:18 PM. |
