Thank's Doc Holiday
Bravo one props on the way home DOC, again thankyou very much and keep us posted when you get a chance to put them to the test.
Hey Darin,
Thanks for the good service. Hope to see the props on UPS tomorrow. Will try them out next weekend and let you know. Mark |
Sounds like some good follow up their from Houston Prop, keep up the good work guys, and Mark let us know how the props work!
I looked at one of the props before it was reworked. As bad as it looked before being reworked, I am currios as to how much better they will run now.
TURBOJACK
TURBOJACK, Thank's for stopping in the shop the other day, Yes the props as you saw were out of balance bad and the trailing edges and tip's were off. doc needed about 400 more rpm,I thinned them out repitched and balanced and polished ,I also trimmed the trailing edge in the pitch line of the cup for more rpm but added some on the tips .I hope we hit it right on the money as the cupping is very critical as not enough or just a little too much will make the world of difference. But with a little more lift we are hoping the rpm and speed will increase. let us know when the chance arrives.
Originally posted by Turbojack I looked at one of the props before it was reworked. As bad as it looked before being reworked, I am currios as to how much better they will run now. |
Hey Darin, do you have a machine called a "prop scan" I think it is a digital dial indicator, to measure the blades? or how do you do this? thanks for the info
Mark |
TURBOJACK, Thank's for stopping in the shop the other day, Yes the props as you saw were out of balance bad and the trailing edges and tip's were off Should have said this instead of as bad as it looked |
prop scan
prop scan is availabe for my use when needed, the machine run's 60,000.00 and i do not own one , the scanning machine really comes in to play when working on large inboard propellers. I use the traditional pitch block ,pitch and rake indicators on most all of the work.
Ouch! 60000.00 man thats a lot of cash, I could buy a cool boat for that, I have always heard pro's and con's on that tool, sounds like it would be hard to get your money out of it!
60,000.00 prop scan machine
yes it's not worth the money ,and if I had the money Iwould buy something a little nicer than a prop scan machine .,ha, not that I don't believe in up dating equipment but this is not really necessary when it comes to outboard and sterndrive propellers. TAKE CARE,Talk to you later just getting home and it's 12:30 a.m. in Houston another long day as we all know about.
| All times are GMT -5. The time now is 10:10 AM. |
