-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Potential soft floor issue? (https://www.offshoreonly.com/forums/baja/342181-potential-soft-floor-issue.html)
formula1 10-24-2016 06:51 PM
I'm looking at a 2000 Baja 280 Sportfish. Anyone know these boats? The boat seems in really nice shape EXCEPT, where the four corners of the center console bolts to the floor, the floor "gives" a little (the rest of the bolts into the floor for the center console and leaning post are fine). Also, around the leaning post, the front two bolts (on each side on the outside corners) the floor feels the same. The rest of the boat seems great. So, could it be a soft floor or just a design flaw where after fifteen years of walking and leaning around these corners, the area has gotten weak?
Baja Rooster 10-25-2016 03:24 PM
I can't speak for your boat at all, but I know the Baja 272 models come spongy, and if you want that firm feeling then plywood has to be glued to the underside.
johnmiffco 10-25-2016 05:08 PM
pull out 1 of the bolts in the soft areas,,,,,stick a pic in crooked and see if there is still any wood left around the hole
as screwed down consoles and towers water leaks in through the screws when they are not sealed or come loose and wood rots
formula1 10-26-2016 11:05 AM
This is what the seller stated, however, it turns out it might be a "flip" since they only have owned it 2 months and fixed it up a lot. I mean it looks like new. He said he could fix it if it was a deal breaker. I just don't want to have more water get into the floor and possibly make it worse like johnmiffco stated.
