25 Outlaw Whipple Merc 525 EFI
So I started this project last year with tabs, hydraulic steering, extension box, re-rig, basically all the boring stuff. I went the opposite direction that most go by trying to get the setup done before the HP. After the upgrades last season I went from a 70mph basic starter upper 25 outlaw with a bblades labbed 25 mirage to a 68mph outlaw with a stock 26 bravo 1 that was much more capable in the rough water (ext box and tabs) and had a lot more control from the hydraulic steering as well as the four blade. I'm confident that if I would of had that 26 bravo 1 labbed I would've been above 70mph.
Anyways now I get to do the fun part. I was looking at a couple of the new Merc motors, 540 and 565, because the 2 year warranty piece of mind, and a couple of used 525s mainly because I'd be able to run a Bravo XR for the time being. While I was good with going with a NA motor others convinced me that if I was going to do this that I should make it worth while right away. So I was able to get a pretty good deal on this Whippled 525 and so far am very happy going this route, however I have not had the pleasure of seeing how fast 96 gallons can be burnt yet. Yes I know that "I'll never get the money spent on the Baja back out of it". Not even close, but this boat works for us very well and is in fantastic condition and looks good. The 25 outlaw really is a very versatile hull. But the point of me starting this thread is for advice and tips along the way from more experienced go fast riggers and builders and DYIers than I, NOT for bragging purposes (seems in the winter months a thread can go all cockamamie in a hurry). I'm still kicking around ideas on how to do the plumbing and a couple other misc things that I will ask about when I get to those steps. Sorry for being long winded but I thought I'd give a little background on the project. NOW PICTURES! http://i1098.photobucket.com/albums/...CB836FD4F2.jpg http://i1098.photobucket.com/albums/...14F959AE42.jpg http://i1098.photobucket.com/albums/...C89A1777D9.jpg http://i1098.photobucket.com/albums/...E8D95116A4.jpg http://i1098.photobucket.com/albums/...EDB0BECBA9.jpg http://i1098.photobucket.com/albums/...2B1E23970F.jpg http://i1098.photobucket.com/albums/...F950F56B68.jpg Thanks guys |
96 gallons...you'll be a regular at the pump. Looks sharp.
Threads like these make OSO great, thanks for sharing!
My plan is to do the same to mine when I get the funds... I have some serious play in my steering so I'm looking for a ext. box and hydraulics this spring.. any advice on adding one?
Originally Posted by iaoutlaw
(Post 4530737)
Excellent start to your project! The engine compartment is going to look great, very detailed job.
(Post 4530737)
I'm a fan of Mercurys ITS system, very clean, 7" of setback, keeps exhaust routing for y pipe for captains call or quick and quiet, and hydraulic steering is incorporated. However without redoing the transom you cannot raise your X. My boat is setup very close to how Wildcard 09 did his. He was able to get very respectable speeds with his motors and ext box. 81 with a 525efi and 84 with a 600sci, probably could've got one or two more clicks out of the 600 but he was not chasing the top end number. I have talked to Stephen, (wildcard 09) a number of times. As far as 25 outlaws go he's The Godfather if you ask me. I believe he's still running his around in Germany. |
Very nice - good luck with your build !!
Ok so this motor has a Hardin two stage SS water pump on it. One stage feeding the motor cooling and the other feeding the moaic intercooler. The pump currently has a common input to both stages on it. How much water can a imco scx provide? Imco says plenty if you open the hole in the lower up but it'd be close feeding the two stage pump. My original plan was to have the scx and a thru hull feed my hardin strainer and then one 1-1/4" hose to the pump input but somebody along the way mentioned the possibilty of the two pickups fighting each other... I would like to try and run off the drive pickup only and see what kind of pressure is maintained, but then there's the possibility of pressure dropping if I have to use a lot of trim? I'd hate to only strain the water for the intercooler and not the rest of the motor. How would some of you guys do it?
Thanks for the compliments and input guys! |
Leave the drive alone. Dont open up the lower holes. Install the engine, run the boat. Make the call later. There are too many stories of guys making changes in anticipation of "enter your upgrade here" only to put the old parts back.
I can tell you this - opening the holes will slow you down. If you just plug the stock lower holes its good for almost 2 MPH. You probably cant due to the 2 stage pump. But, you may end up with a transom pickup anyway. If you leave it alone consider this, at 70MPH You are pushing WAY more water thru those 4 little holes than you think. If you have issues with the upper holes, fill them 1 at a time from the top. This is unlikely, I have had my drives way high and way trimmed and havent heard of an issue on most Bajas, however, I have heard of it on fountains but you are talking about something that is significantly higher. |
| All times are GMT -5. The time now is 10:28 AM. |
