-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Need Help!, I'm going to install trim tabs on my H2X (https://www.offshoreonly.com/forums/baja/34545-need-help-im-going-install-trim-tabs-my-h2x.html)
SparkyAZ 10-09-2002 05:17 PM
I was wondering if someone with and H2X can help me out with some pictures of the tab placement on the hull, motor placement, wiring and where the line come through the hull (engine comp), placement of indicators in switches.
Email is [email protected]
I'm going to install the same that the factory installed unless, somene has had better luck with a different brand
http://www.insta-trim.com/main.html
Mike
H2Xmark 10-10-2002 07:11 AM
Hello there, I have a 2000 h2x it came from the factory without tabs, when I made a deal on the boat I had the dealer install the dual ram tab kit with led indicators, they did a good job on the install, remember measure twice drill once! I will see if I can get a digital camera and take some pictures for you, { my sony camera is broke } good luck
djm 10-10-2002 09:09 AM
Here are some pics of the trim tabs and pump I inadvertently took awhile ago. Go to the Boat for Sale gallery.
http://community.webshots.com/user/djmdammit
Good luck with your project, you'll love the boat with tabs!!
