-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Prop Question (https://www.offshoreonly.com/forums/baja/350412-prop-question.html)
Hogheadsena 10-20-2017 02:26 PM
Prop Question
2006 35’ Outlaw and I have 496HO’s and currently running 4 blade 26 pitch. Only getting 66 mph. What prop should I be running? Stock 496HO
Padraig 10-20-2017 03:42 PM
What rpm?
padraig
Hogheadsena 10-20-2017 03:43 PM
Originally Posted by Padraig (Post 4589086)
What rpm?
padraig
Around 4750 at WOT
Padraig 10-20-2017 04:42 PM
Max RPM for a 496 HO is 5150. You are 400 rpm low. Either low on power or too much prop. What brand prop and what model? Hopefully someone with Baja 35 experience will chime in.
Padraig
Hogheadsena 10-20-2017 05:52 PM
Padraig
Bravo 1 mercruiser brand 26 pitch
nailit 12-07-2017 09:16 PM
Had a friend with same boat and engines. He ran same props just over 70.
I dont think props are your problem. You may want to have your engines scanned for codes! I went through the same thing.. 4 years later, I scanned and had knock codes on both. Picked up 5mph after I changed 1 sensor and cleared codes!
