-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Stiff Steering (https://www.offshoreonly.com/forums/baja/353945-stiff-steering.html)
Kent 05-14-2018 07:29 PM
Stiff Steering
Hi all I have a 2007 26 Outlaw. Question- the steering is stiff and I am hearing this is the way it is. Is this true? If not, what can I do to make it less stiff? thanks
Griff 05-15-2018 01:27 AM
What kind of steering??
Cable??? Add On Hyd?? or Full Hyd??
Kent 05-15-2018 02:04 PM
cable
hey there
it is cable, any ideas??
Griff 05-16-2018 01:34 AM
It could be the helm, in the rack or cables in between. Its hard to say without being able to feel how stiff. It might be nothing.
It shouldn't be any stiffer than any other single engine engine cable steering. Try to find another boat with cable steering and compare.
You would definitely like full hyd and full hyd keeps gimble rings from going bad since the load is on the rams and not the steering pin.
Kent 05-16-2018 06:52 AM
Thanks Griff
Ok I will look into this, my friend has the same boat.
