Consumption at 30 miles an hour, 38 special
Hello in order to bring back a special baja 38 in one go, I would like to know the consumption of the engines per hour at 30 miles per hour. Thank you
Baja 38 Special with 2 mercruiser 502 mag mpi. |
Approx 15 gph per engine I’d say
Thanks my friend :kiss:
Im guessing 30 is about 3000 rpms. Merc shows 12.5 (so call it 13) gallons pr hour burn rate at 3000 rpms, pr engine.
Thanks, can you explain more please, thanks, best regards
Thinking 30mph is going to be as slow as that boat will run and stay on plane.
He's suggesting you'll burn 13 gallons per hour per engine at that rpm, whereas the previous poster suggested 15 gallons per hour per engine (they are both close). You might find that hull needs to run more like 35-38 mph to be as it's most efficient. Either way, figure 1 mile per gallon for your trip and you should come in having burned a little less than that. |
My formula was between 25-30
my sonic is 30-35 gal/hour all those between 3200-3400 rpm so most answers given here are good! |
Thanks, from Cannes ( France) to Perpignan, I have 230 miles.
So how many gallons I need to make this distance? For you the best speed/gallons is 36-38 miles/hour. So 6h30 time traveled. So how many gallons for 2 motors? |
about 1 mile per gallon total. So 200 to 230 gallons total for the trip.
Originally Posted by Ferdi
(Post 4736495)
Your fuel consumption will be higher with a heavier fuel load (more RPM to maintain same speed) so calculations are a bit of a sliding scale full of fuel vs. light...plan for a reserve % as a "just in case" |
| All times are GMT -5. The time now is 10:32 AM. |
