-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Alarm went off, Why? (https://www.offshoreonly.com/forums/baja/366757-alarm-went-off-why.html)
PA.WOODCHUCK 06-21-2020 10:52 AM
Maybe a sensor or you still have a cooling issue?
2000 baja 232 06-21-2020 03:35 PM
But if I had a cooling issue wouldn’t it be present on the gauge? The temp was at 150-160 when the alarm went off.
AllDodge 06-21-2020 04:15 PM
No, not necessarily
Don't know the serial number but being a 2000 model I'll guess The temp sender signals the ECM and the ECM sounds the alarm for an over temp. The gauge has another sensor which just provides info to you and does not talk to the ECM
2000 baja 232 06-21-2020 04:24 PM
That was my thought. So with that being said if the sensor that talks to the ECM is faulty that could trigger the alarm. Assuming the sensor that talks to the gauge is good, the gauge was reading 150-160 went the alarm went off.
AllDodge 06-21-2020 04:32 PM
Use a IR temp gun to verify temp at the thermostat housing
