-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Blue 500 EFI (https://www.offshoreonly.com/forums/baja/379066-blue-500-efi.html)
baja32hs 04-28-2023 01:33 PM
Blue 500 EFI
Looking at a Baja with twin Blue 500EFI's that are still factory sealed with around 400 hrs. Can anyone chime in on what to watch out for or look for on these engines?
F-2 Speedy 04-28-2023 01:46 PM
One of Merc's best imo, Id scan the ecm's to check hours, fresh water or salt ?.........
Plowtownmissile 04-28-2023 01:59 PM
When I was looking at used boats last year, I asked Eddie Young at Young Performance about what to look for with Merc engines. He's extremely knowledgeable with an excellent reputation. I'd suggest contacting him.
baja32hs 04-28-2023 02:52 PM
Fresh water
F-2 Speedy 04-28-2023 03:10 PM
Id at least do the rockers if they've not been done
EDIT: leak down and compression test
SecondWind 04-28-2023 03:23 PM
If you're going to break the factory seal might as well throw some power at it. Heads, cam and tune should squeeze another 100HP out of them. We have a 33 Outlaw at one of our local lakes in central IL w/ a Brad Smith upgrade for 500efis. The boat sounds and runs really strong.
Wildman_grafix 04-28-2023 03:52 PM
Biggest thing is valve springs, head gaskets and valve seats. Did mine at 320 hours now have 780, last 10 in salt still running great.
Stock rockers..
jeff32 04-28-2023 08:10 PM
Had 2 out of 3 engines never opened at 1100 hours, and one at 900 hours. The 900 hours broke a valve, i wanted to rebuilt engines anyways... so in your case i would do top ends only and might see above 1100 hours!
25OutlawSST 04-29-2023 01:19 PM
36 Outlaw?
You looking at the 36 Outlaw sale??
baja32hs 04-29-2023 03:29 PM
Thanks, I'll look him up
