Looking for a some dimensions on a Baja 240/24 outlaw hull
I have an 88 240. Bravo/454. Boat supposed to have had x dimensions raised and was looking for someone to maybe measure theirs or give me a rough idea where stock height is/was. Thanks!
How far is the propshaft below the bottom of the boat?
If it’s around 7-8” it hasn’t been moved up |
I’ll have to try to find a way to get the drive down and level on the trailer. It’s sits pretty low. Was hoping someone might have had just a rough measure from the bottom outer transom assembly to pad or something of that sort. But I will try as soon as work let me and report back.
Like what was stated above the x will be around 7 inchs below the bottom they were real deep no good props at that time . I just raised mine to 3.750 below and i put it on a 12 inch box . mine is a 1989 and it was real deep with 625 hp it went 76 mph with a 26 bravo none labbed with a labbed it picked up 2 mph. .. Most 24 outlaws if you put a 2 inch shorty lower they picked up around 4 mph so they like coming up as they should. I am starting this year with a 540 ci makes around 750 hp we will see what it will do.
| All times are GMT -5. The time now is 04:34 PM. |
