rub rails
i need to find the mfg. of the white rub rails used on the outlaws. i would think that they would use the same size on all the models
i have a 97' 29. i was trying to clean it up the other day but it was not looking that great... any tips would be much appreciated.... jc ;) ;) |
I replaced the rubrails on my 1988 Force 320 with ones from West Marine
How diffecult was it to replace the rub rail?
Usually not hard to replace.
Pull out the old rubber, start with a screwdriver at a rubber joint. Loosen up a joint section of the aluminum. Lubricate the rubber and start sliding. Alternately you can snap it by warming the rubber so it is more flexible. Your fingers will be tired. |
Hey, don't give up trying to clean that rub rail yet! I clean mine once a year with Soft Scrub with Bleach. You might have to rub it awhile (punn intended), but it will get it white again! I can't believe how much better the boat looks with a clean rub rail.
Sometimes if you clean it good with lacquer thinner, then mix up a paste of baking soda and water, and give it a good scrub with the mix, rinse with water and it will look great!
I have tried it all and Acetone works the best, make sure you wear gloves, you can buy the stuff in hardware stores or paint dept.
Finger nail polish remover
rub rail
i tried a little paint thinner last weekend and it did not do much..
i know that lacquer (spelling) thinner is stronger, i just worry about melting the rubber. i like the idea on baking soda.. yes. a clean rub rail makes the boat look great. a couple of years ago i had the molding and rub rail replaced along with the ss insert (on my 272) and i could not believe what a difference it made. jc:cool:cool: |
Acetone is the trick! It actually melts away a very thin layer of the vinyl. Just keep moving to a clean spot on you're rag, otherwise you just smear back in the grime you just removed. I do mine everytime I come off the water and there is absolutly no sign of damage or change to the rub rail (3 years and running).
Bruce... |
Try scotch-brite and a heavy duty degreaser. Just be careful you only touch the rubber. It will scratch the gel coat.
The lacquer thinner won't hurt anything. If you get some on the gel, it's ok, just don't leave it on there. Wipe it off, and the remainder will evaporate quickly.
Acetone, will melt most anything if you leave it on there just a short time. It works great to clean, but use a rag just dampened with some, and make sure none of it stays on the surface. I personally don't like to use acetone because I know if I spill some in the wrong place and can't get it up quickly, I could do some real damage. Don't let either chemical come into contact with any plastic or plexiglass or it will be ruined. By the way, if you have a pinstsripe that won't stay stuck, you can take a rag just slightly dampened with acetone and wipe off the surface, then take a Q-tip, and dipit in acetone, let the excess dry up, swipe the bottom side of the pinstripe with the acetone-dampened Q-tip, stick it on, and most of the time it will stay forever. Works much better if the surfaceand pinstripe are both warm. |
The company that makes most of the rub rail is Taco they have plants all over the USA the main one is in Miami, Here at Geo we clean rub rail with laquer thinner, if you have any scratches use 600 grit sand paper and rub with a little compound, If you want to you can hit it with a buffer, that will make it really shine and remove the dirt as well
Originally posted by Advantage Hey, don't give up trying to clean that rub rail yet! I clean mine once a year with Soft Scrub with Bleach. You might have to rub it awhile (punn intended), but it will get it white again! I can't believe how much better the boat looks with a clean rub rail. |
I use Acetone, but be sure to wear gloves, very volatile chemical.
Rub Rails and Anything Else
I keep a can of GOOF OFF in the boat along with a roll of paper towels. I wad up a paper towel and pour a little Goof Off on it and most anything will come off. Goof off will even take scuffs or stains off of your upholstery especially if you have white seats without harming them. You can get it at any hardware store is costs about $2.50 a can. One can will last you a long time because you don't need much when you use it. Beware of immitations, I have tried them and they don't work, Goof Off works the best. Eric
| All times are GMT -5. The time now is 03:36 AM. |
