-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Max RPM on 496 mag not ho (https://www.offshoreonly.com/forums/baja/47508-max-rpm-496-mag-not-ho.html)
liquid asset 04-10-2003 09:52 PM
A couple of freinds of mine have 496 mag's, the dealer told them to turn them 5,000 if I'm not mistaken the rev limiter is at about 4850 and peak horsepower is at 4,600 does anyone know the facts?
Just wanna save buddies time and money if they've been misinformed
Dock Holiday 04-10-2003 10:09 PM
Liquid,
You may want to post over on Tech Q & A so those in the know will see it.
CigDaze 04-11-2003 07:07 AM
1 Attachment(s)
Here are the facts:
Max WOT RPM Range for the 496 MAG(375HP) is 4400-4800.
Rev Limiter should be set at about 4850.
Also, Here are the HP and Tourque Curves for the motor:
CigDaze 04-11-2003 07:09 AM
1 Attachment(s)
In comparisson, Here are the HO Curves:
CigDaze 04-11-2003 07:11 AM
For more information Visit here:
http://www.gm.com/automotive/gmpower...rine/index.htm
:cool:
liquid asset 04-11-2003 11:17 AM
Thanks, BAJA DAZE
bikinilover 04-14-2003 06:22 AM
So if I am turning 4700 to 4750 RPM I should be good?
CigDaze 04-14-2003 07:05 AM
Assuming the 375hp version, you're in the perfect range for your engine. You want to be as close to the upper end of the range as possible. Look here:
RPM Range Service Bulletin
liquid asset 04-14-2003 07:04 PM
I knew with 6,447 post you could help with something
CigDaze 04-15-2003 07:24 AM
"Send me on a mission, I'll complete the objectives. Leave me flounder, I'll find another mission."
-Unknown 21 Century Post Whore Extraordinaire
