-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   A/C question (https://www.offshoreonly.com/forums/baja/49342-c-question.html)
Bajaforce 05-06-2003 08:13 AM
A/C question
I'm trying to locate the valve for the water supply from the thru
hull fitting to the A/C unit. The manual says that it should be right
by the unit but I sure cant find it. As always I appreciate any and all help from you guys.
Thanks,
Jeff
BAJA342 05-06-2003 10:39 AM
Jeff,
If you mean the valve to close the supply. Mine is mounted in the engine compartment by the supply feed pump.
Frank
Dock Holiday 05-06-2003 06:09 PM
1 Attachment(s)
Hope this helps.
Dock Holiday 05-06-2003 06:15 PM
1 Attachment(s)
The thru hull fitting comes up through the hull in front of the port engine and the shut off valve is located on top of it. The water then passes through the brass sea strainer and into the pump mounted on the fire wall. Then the hose goes up the port side of the boat to the A/C unit mounted under the berth. Then it exits out a fitting on the starboard side.
This is the A/C unit.
Bajaforce 05-06-2003 07:54 PM
Frank and Mark,
Thanks a million.
Jeff
