-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Single engine to Twins driving/docking advice? (https://www.offshoreonly.com/forums/baja/50232-single-engine-twins-driving-docking-advice.html)
Highmark 05-17-2003 10:12 AM
Anybody have any hints or advice on what to do or not to do when driving a boat with twins v. single engine? I stepped up into my 33 from a 272 and would like to know if there are any things I should do or not do with twins. First ride went very well and I'm adapting to the larger boat quickly but I thought it wouldn't hurt to ask.
HyperBaja 05-17-2003 11:19 AM
I havent driven one, but Im sure its the same as the first time you docked a single motor boat, go out on a calm non busy day, throw some fenders on the sides and practice. Im sure you already know you can put one motor in reverse and 1 in forward and sprin it around a lot easier than a boat with a single.
Tommy
JaayTeee 05-18-2003 10:05 AM
Keep the drives in "staight ahead"
position, and do you maneuvering with your
shifters, use the steering wheel as little as
possible.
my .02
jt
liquid asset 05-18-2003 11:56 AM
I agree, twins are way easier to dock or raft up than singles, you can control everything with the sticks
bajacraig 05-18-2003 07:44 PM
same as jt
do not use the steering wheel at all.
I moved up from a 252 islander this year to a 33, no problems.
