-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Warped Seats (https://www.offshoreonly.com/forums/baja/51266-warped-seats.html)
Baja232 05-31-2003 10:54 AM
Warped Seats
I brought my boat home last weekend from storage to clean it up for the season and noticed that the two front "bench" seats in the open bow are warped badly. (232 islander with open bow)
Has anyone else experienced this and is there a way to fix the problem. I tried taking them out, and put soem wieghts on the warped part, but it's not working.
Anyone have a clue how much new seats from Baja would cost?
thanks,.
Holy Smokes 05-31-2003 01:52 PM
Likely they have plywood bottoms that got some moisture in them over the off-season. Should be pretty easy to pull the vinyl and pad and replace the plywood. Use a good quality exterior grade or marine grade plywood. You can then glass the plywood to make it last longer.
