Originally posted by outlawntexas How do you plan to exhaust the generator? My Westerbeke exhausts through a large muffler just outside the hush box, then through about 6' of marine exhaust hose to the transome. It then exits with a Salisbury flap. This setup uses water for cooling the exhaust as well as the heat exchanger for the engine. Bruce... It will be strapped onto the swim platform. I have seen this done before and have talked to a couple of people here on OSO that have used one like this. If it doesn't work, I will still have a good generator for many other uses. I will keep everyone posted. |
You better be carefull with that strap on.:D |
Originally posted by kr1276 It weighs 46 lbs and I use the Marinco 20 amp adapter on my shore power cable. West or Boat US stocks them. For OSO'ers I will sell them for $850.00 which includes shipping. Approximately, what size is this unit? Both in footprint and height. Thanks. |
Originally posted by Dock Holiday Bruce, It will be strapped onto the swim platform. I have seen this done before and have talked to a couple of people here on OSO that have used one like this. If it doesn't work, I will still have a good generator for many other uses. I will keep everyone posted. |
Originally posted by Baja Daze Wow. That's quite reasonable, both in weight and price. I never really looked into it, but I imagined them being much heavier and more expensive. Approximately, what size is this unit? Both in footprint and height. Thanks. |
Thanks!
i had a portable generator mount on the fly bridge of a slow boat i owned i vibrated the hole boat
maybe you could mount it on a float that way no vibration or co poisioning or do what we use to do hooked up with a guy with a big boat we would plug in to his pwr cardoctor |
| All times are GMT -5. The time now is 02:08 PM. |
