-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   baja 272 speed (https://www.offshoreonly.com/forums/baja/54627-baja-272-speed.html)
gtxjoe 07-16-2003 09:18 PM
baja 272 speed
i have a 1996 baja 272, it has a 502mpi 415hp motor with stock prop, i am getting a reading of 65.2 on GPS, just wondering if this is how fast the boat is supposed to go?
baja bailey 07-16-2003 09:33 PM
I think that is probably about right. I have a friend with a 272 and 502, I think his best ever GPS was a little over 68...
Luv-N-It 07-17-2003 06:43 AM
Man,
You both are seeing some great speeds. The best I have seen with my 272 502 MPI has been 63.7 MPG on GPS. I was a little heavy, however, you guys are getting great speed, especially 68 stock with a 272:eek: :eek: :eek: that boat most have come out of the mold perfect. I have a friend with a 272 and the 496 HO and that is the best he has seen, 68 GPS!
Dock Holiday 07-17-2003 08:09 AM
Very best speed I ever got from the 2000 model we had with 502 Mag was 64 on GPS.
Great boat, rides and handles very nice and good size to trailer also.
They will go fast if you want them to, MillerLite on here has one with a procharger running low 80's.
But you are right where you should be.
What slows Luv-N-It down is all that fancy Chit in his cuddy along with the Purple paint!!!!!!!!!!!!!!!!:D :D :D
29Fever 07-17-2003 08:16 AM
Friend had a 1994 502mpi...64MPH also on GPS.
MillerLite88 07-17-2003 08:25 AM
My 1997 272, 502 mag efi was 64mph in stock form. I added a stern jack and stainless marine exhaust and that took it to 68mph. At that point I added the Procharger with about 5-6 lbs of boost and that took me to 80-82mph.
-Mark
Luv-N-It 07-17-2003 05:11 PM
Dock, LMAO:D :D :D However, I think you have it wrong. What slows me down is all that extra red paint peeling of the red Duramax cause I can't keep my foot out of it while towing, hence creating more drag for the 272 on the water:eek:
Dude, sometime soon I'm coming down to see the lake you call home and we are going to have to hang out on the water. I'll bring a set of chains with me so we can play tug a war in the parking lot with the trucks:D You'll get me on the water, but we'll have to see what happens land side;)
By the way grxjoe, I have an 1996 272 25th anniversary Baja w/the 502 Mag MPI. With all the fancy stuff inside:p
Dock Holiday 07-17-2003 07:39 PM
I'm counting on it!!!!!!!!!!!!!!!!!!!!
Thanks for always being a good sport!
Give me a heads up that you are coming so we can come and meet you if the truck breaks down on the way. Those are some pretty BIG hills in West Virginia. :D
Luv-N-It 07-18-2003 06:54 AM
Doc, you took the words out of my mouth. I'll stop by the hotel room and pick you up:D
http://www.offshoreonly.com/forums/s...threadid=54638
Speed Demon 84 10-23-2019 08:19 AM
In my grandpas 272 with the 454 and a half tank of 100 octane race gas we hit 60 mph
Baja Rooster 10-23-2019 01:36 PM
Supposedly BBlades has a tune for the Mirage+ that’s good for a few mph, but you’re right where you should be with a stock set up.
Griff 10-24-2019 01:16 AM
The race fuel is probably costing you a couple mph. You should run 87 octane.
Dakotabo 09-01-2020 03:26 PM
1997 Baja 272 502
66.9 mph
bajaman 09-20-2020 05:13 PM
What prop and RPM? Assuming you're pulling close to 5000 rpm?
Dakotabo 09-26-2020 04:53 AM
4800 rpm, mirage plus prop 27 p. I actually hit 68.1 mph the other day on the gps.
obnoxus 09-26-2020 04:55 PM
My best performance was with a 23 Mirage Plus turned up a bit. 27 was to much prop for mine
sledfreak 12-19-2020 08:04 PM
68 on gps on my 99 272 502, with 23M+ labbed with 496HO manifolds.
