272 anchore locker
Any body have any eperience with the drain in the loker clogging and not draining. If so how did you fix?
Thank You |
I kept rodding it out with a clothes hanger and I cannot remember if that ever solved it.
I had the same problem. I inspected mine really close one day and removed the drain plate and it was plugged with caulking/silicone.
Also, do a search on this subject in Baja or check back through previous threads. This has been an issue with other 272's also. |
I read somewhere that you can pull a front cuddy speaker out and reach all the drain lines
Had the same issues with my 272. You only need to pull the speakers for access. It is not easy getting in through the speaker openings, but doable.
I used about 25psi through the opening in the hull.
Thank's every one I'll try all and let you know what works
| All times are GMT -5. The time now is 09:15 PM. |
