-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   496homag in 272?? (https://www.offshoreonly.com/forums/baja/67531-496homag-272-a.html)
boatfun 12-31-2003 08:31 AM
496homag in 272??
Gentlemen,
I am repowering to a 2003 496 MAG HO in a 1996 272 Baja. The engine has 12 hours on it. What kind of oil should I use? One suggestion I had was synthetic 30 or 40 weight as opposed to the Mercruiser oil???? Any suggestions?? Will I have problems with the rings sealing with the synthetic oil?
My goal is 70mph but I think I will need all of the tricks to get there!!
thanks!
Dan
obnoxus 12-31-2003 09:22 AM
496 Mag HO and headers and you should be right about there. Try a 25 Mirage Plus Prop.
Any good quality straight 40 weight will be ok changed frequently.
PERSONALLY,, I run straight 40 Royal Purple Synthetic.
boatfun 12-31-2003 09:34 AM
thanks! where do you buy that oil?
Madmax 12-31-2003 12:43 PM
It's gonna be close. My friend has a 2001 with a 496HO in it. It runs 67-68 gps. Lab a 25 mirage and you should be there.
Good luck.
Btw, e-mail me on your 454. See your ad.
obnoxus 12-31-2003 05:52 PM
Winners Circle in Joilet,IL About $75 for 5 gallon pail.
