-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   towing info 29 outlaw (https://www.offshoreonly.com/forums/baja/69122-towing-info-29-outlaw.html)
thosetwins 01-16-2004 10:13 AM
I just bought a 04 29 outlaw twin 496mags w/triple axel trailer. Heres the low down. I have a 99 ford expedtion 5.4, heavy duty towing and cooling pk. and load leveling suspension 2wd. Iam under no illusions about this set up. I do 85 % of my boating at the lake where i keep the boat stored which is 5 min from the ramp. my main concern is 3-5 times a year i tow 3-6hrs to other lakes. can i get away with this. If not i have a friend who has a heavyduty f250 diesel who can help here. can the expo. tow any distance at all? will i even be able to get up the ramp? I can buy a new tow vehicle if i have to but wanted to wait till next year before doing so. Any info here would be much appreciated. thanks
Steel Outlawed 01-16-2004 10:34 AM
Check the owners manual for the gross tow weight. I would not exceed what it says, by much. The highway tow should be no problem, it's start and stop traffic that will work on it.
Dock Holiday 01-16-2004 11:37 AM
You are probably OK from what I have seen.
It will pull it and it will handle OK, just be extra careful to allow added distance for stopping.
Make sure your trailer brakes are in good condition also.
If you decide to upgrade a 3/4 ton will be the way to go.
Good luck
Dock Holiday 01-16-2004 11:40 AM
I am basing the above statement on a friend that pulled a 35 Fountain with a 1/2 ton Chevy Sub.
I have seen a Baja 38 Special pulled with a vehicle JUST like you have, but the guy only did it once! He could not stop it!
The truck brakes were not strong enough to activate the trailers brakes. (13,000 Lbs) :eek: :eek:
thosetwins 01-16-2004 11:57 AM
dock, have a question for you. i gather you boat on lake norman? i live in okc,ok my good friend of 15yrs is sales manager of westport marina. He moved to that area in 1999 if you see ellis tell him i said hi. Thanks for all your info :)
29 OUTLAW 01-16-2004 12:26 PM
I towed for one year with a Ram 1500 5.9. No problem.
KBUSH1 01-16-2004 12:51 PM
unfortunately, i had to tow my 2000 342, which i purchased in florida with my 02 dodge 1500 4x4 until its lease ended. this truck is rated for 7200 lbs which was okay for our 272, but the 342 is close to 10500. never had a problem towing, launching etc. even from florida. like everyone has said, make sure your trailer brakes are working, and take your time. acceleration and breaking are a lot slower than usual. fortunately, new ctd dodge is on order....
Dock Holiday 01-16-2004 01:16 PM
:D :D :D
I did not know Ellis had any friends?????????
Yes I know him, he has ridden on my boat.
He has a beautiful 25 Outlaw with a custom paint job and a really sweet wife.
He is always right in the middle of anything happening on Norman!
Funny, but we met him before he had the Baja line. Strange how things work out.
What is your name?
Advantage 01-16-2004 01:47 PM
I think I can help you with your question. I have a 1999 29' Outlaw with a triple axle trailer and tow it with a 1999 Ford Expedition 5.4. I tow the boat at least every weekend about 20 miles. I also tow the boat on some long trips during the summer upwards of 8-9 hours.
Like everyone else said, make sure you anticipate your stops, and make sure your trailer brakes are in good working order. The truck has no problem hauling the boat aside from stopping. It will pull the boat out of the water on a steep ramp no problem. The only thing I would recommend would be to get air bags in the rear. Otherwise, I would save your money and use your Expedition for towing.
WHOSNEXT 01-16-2004 01:49 PM
NEW29ol, I had the same truck and pulled my 25 outlaw around no problem, I know the 29 weight's more but my buddy used my truck all the time to pull his 30' scarab and same thing (no problem) you just have to remember its back there and give plenty of room to stop.
thosetwins 01-16-2004 02:57 PM
DOCK, my name is john kelly and you tell that guy (ellis) that he better take A-1 care of you. he he. I just might be up there to visit this summer looking forward to meeting you and hitting the liquid highway. thanks to all the info from everyone!! Thanks a bunch!!
H2Xmark 01-16-2004 06:50 PM
you will not have any problems with the tow rig you talk about, just listen to the above about slow stops ect.
I still tow my 29 outlaw on a steel triple axle trailer[twin 454's] with my chevy 1500 ext cab 4x4 , the only problem is on steep boat ramps when you pull the boat out it will spin the back tires[ have to put it in 4 wheel drive] have fun with the new boat
skygod 01-16-2004 07:58 PM
Just be aware, a 29 full of gas and on the trailer will weigh around 9,000lbs. Mine crossed the scales earlier this year at 9,400 lbs full of fuel, trailer, and gear. Stopping distance is the key. Make sure your hitch is rated for somewhere close to that.
thosetwins 01-16-2004 09:36 PM
air bags
whee do you get airbags for rear end? how much are they? Is it similar to load leveling suspension?
DJW 01-17-2004 09:37 AM
I got rear air bags for my Tahoe from Summit. Makes a big difference. I pulled a Formula 311 which is bigger than a 29 Outlaw, you need to have good trailer brakes to assit in stopping. I also upgraded to tires with a load range D rating. The stiffer side walls eliminates the truck from swaying on the softer, better riding, stock tires.
Saleen367 01-18-2004 03:04 PM
new29ol,
have a friend that pulls his 33 ol to Poker Runs 3 hours away. He's never had a problem with his Expedition.
I have an F150 SC 5.4 pulling my 25 OL and the only thing I would like to change is the brakes as well.
Keep an eye out for the idiots.
Chart 01-21-2004 07:46 PM
I had a 97 Expo with load-leveling. Yes, it is the same as air bags. I only pulled a heavy trailer once (16 flat bed with wooden floor and a full-size sedan on it, all covered with 1/4" of ice from freezing rain. I have no idea how much that weighed, or where it was distributed, but it was a lot.)
The Expo "chine walked" the entire time. I now know the rear air bags shared their air, and when one side of the truck dipped, the air rushed to the other, then came rushing back, etc. Pulling the empty trailer the truck did great. Engine is fine. Brakes arn't bad. Wheel base is a little short.
Miss the expo. It was a snap to drive in the city and in parking garages.
Good luck
