-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Bad stringers (https://www.offshoreonly.com/forums/baja/72256-bad-stringers.html)
Smitty 02-20-2004 03:38 PM
Bad stringers
Were there any problems with either the 33 or 36 Outlaw stringers ??? I have read about problems with the 29's.
I am looking at either a 33 or 36 between 1998 and 2000.
Thanks,
Dave
29 OUTLAW 02-20-2004 04:24 PM
Back around 1999 I read something about 36 O/L stringers popping in boats equipped with "big power". That's all I know.
JaayTeee 02-20-2004 06:25 PM
A friend of mine has a 98' 36,
it was sent back to the factory
in 99' for stringer work.
From the looks of it, they added a
cross stringer underneath the engines.
I've seen later 36's, and they have this cross stringer
The 98' I spoke about had 502's, (that were
pro-charged) so I don't know if the recall
was select or all units.
jt
reefmagicmarine 03-05-2004 07:49 PM
Dave,
The information on the cross stringers is correct. The big HP boats would crack the base of the stringer from the flex. The cross bracing cured the problem.
Bill
