-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   36 baja question (https://www.offshoreonly.com/forums/baja/72535-36-baja-question.html)
29scarab 02-24-2004 02:32 PM
36 baja question
Friend is looking into a 36
It has 525 blower motors
Extension boxes
How fast do you think?
I think its a 99 or 2000 model.
Dock Holiday 02-24-2004 03:30 PM
My guess is close to 80 MPH.
My 2002 with 500's pushes 26 pitch labbed props to 74 MPH GPS on a good day.
Usually when it is hot and I have full load of fuel I see around 71 to 72 on GPS.
It may not be the fastest, but I guarantee you will not have to slow down for any water conditions!
Hope this helps!
Buddy OO 02-26-2004 03:18 AM
36 speed
my 01 with 496ho's ran 70 with 500hp the boat runs 73, with 525's old sc's will run 75. boxes probably dont help speed on this setup at all.
outlawinil 02-26-2004 11:02 PM
I have a 2000 33 Outlaw with 500hp's. 27 Mirage plus props will not hold so I called Mercury Racing and they said lab the 27 that I would not be happy with four blades, they said not to run them on Outlaws. Had a chance to buy a pair of labbed 26 Bravo 1's to find out for myself. Handleing was great and so was holeshot but lost 8 mph on top end and the nose digs and the ride really suffered.
I could barely touch 70 with a Garmin III+ GPS and the four blades.
I would have to agree with Doc- about 80 if set up correct.
plumbers crack 03-05-2004 06:44 PM
36 outlaw
I am building 509 575 hps for mine now,with stock 502 mag mpi and 23 mirages the boat ran 66-67.I will need new props curious as to why 4 blades performed so bad.any suggestions on props?
outlawinil 03-05-2004 09:03 PM
4 blades lifted the stern of the boat and not the entire boat. The outlaw never seemed to get up on top of the water and run like it did with the three blades. That was the reason I lost 8mph on top end.
