Paging Dock Holiday
Dock, A while back I saw a thread where you had cured the cabin door rattle.Any chance you could send me some pics. of what and how you did it????I've tried about everthing I can think of ,and yesterday riding in the passenger seat I noticed the damn door still rattles....
Thanks Steve |
Re: Paging Dock Holiday
Yes please send pics.
My 33 rattles also and I'm too stupid to understand the explanation without pictures:) |
Guys,
I will be sure and take some pictures tonight and post them. What I did was replace the existing hardware with Hiwin Linear rail and bearing blocks. This is the type of stuff we sell for robotics. It is probably overkill, but it worked GREAT in my application. This is a link to Hiwin that will show you what I used. http://www.hiwin.com/lg/index.html If you are interested in doing it I will sell you the rail and blocks at cost. |
3 Attachment(s)
Some pictures as promised.
This rail is VERY stiff and solid. There are bolt holes every 50 MM (2 Inches) approximately which is more than five times the stock unit. |
3 Attachment(s)
Let me know if you have any other questions.
Mark,
How did you fasten the top rail where it goes behind the dash area???? Is there enough room to get to the screws?????Even the bottom rail looks like it could be a bit-h..... Thanks for the help..... Steve |
Originally Posted by Steve A.K.A RAMPAGE
Mark,
How did you fasten the top rail where it goes behind the dash area???? Is there enough room to get to the screws?????Even the bottom rail looks like it could be a bit-h..... Thanks for the help..... Steve Like the original factory system I did not try and put any screws in that area. It would be almost impossible. The rail I used as about 8 - 10 screws exposed in the entry way, and it is VERY solid. Not having the ones in that enclosed area is not a problem. I think the factory aluminum channel only had about three screws holding it, so this is much stronger. As for height, it was a perfect fit on my boat. I did not even have to adjust the latch on the door. It could not have worked any better on mine. |
Mark,
Let me know the $$$$ and I'll get a check out to you ,if that's OK. Again ,thanks for the help Steve |
Mark,
Let me know the $$$$ and I'll get a check out to you ,if that's OK. Again ,thanks for the help Steve You have mail! I will handle it any way that works best for you. Mark |
| All times are GMT -5. The time now is 12:19 PM. |
