Baja group add your info.
Since the issue of PROP's and speed always comes up and everyone is looking for the best prop and speed out of there boat. I thought the BAJA group should put together a list of what props they have tried and the outcome achieved.
1) What Baja (year) (length) (Outlaw,islander,etc.) 2) # of engines and HP of motor in the boat (310,385,415,etc.) 3) what drives used and gear ratio (bravo) (1.5 or 1.36) 4) Prop used (3 or 4 blades) (brand) (Labbed or stock) (who labbed) 5) What RPM's are you running at WOT 6) speed (GPS or speedo) indicate which one. 7) Prop slip #'s add yours http://www.boatpropellers.com/propcalc.html 8) What conditions did you run in for best speed (calm or chop) (July or Dec.) 9) estimate the weight of your boat loaded down when you got your top speed. 10) For twins are you spinning your props in or out. 11) Do you have hook in your hull or had it taken out or you don't know. 12) and if you have a pic of your boat running at WOT post it. If you tried other props post all of them if you have the info. And if you can post the perfomance difference between your stock and labbed props. PS: To keep this as simple as possible and easy to read only post once with your info. If you try another prop just EDIT your post and add the info to it. Also I you have a question for someone email them so we don't have a bunch of side conversations. |
Re: Baja group add your info.
Here's something we did very similar last year. Good numbers. :)
http://www.offshoreonly.com/forums/s...ad.php?t=39536 |
1) 1997 232 boss, 23' 6"
2) single carbed 502, mildly built est of 415hp 3) B1 1.5 ratio 4) 4 blade bravo one 24p, labbed by previous owner, not sure to what 5) 5050 rpm 6) best of 69.7 gps 7) .089 slip % ? 8) calm to 1 ft chop, april in OH 9) 5100 lbs; four adults, gear, 50 gals gas (4 blade prop has lots of stern lift, runs faster with more weight, allows more trim) 10) -- 11) hooks have been removed 12) pic on the way Have tried a 25p 3 blade mirage plus, houston props accelorator design, only hit 68.5 but couldnt turn past 4800, hope for better results after Darin does some tweaking. |
'old Baja'
1) 1993 Baja 272 Shooter 2) 1x540ci Merlin N/A 625hp 3) Bravo w/ nosecone 1.5 4) Merc Bravo 1 24" 4 blade 5) 4800 6) 76-78 GPS & speedo 7) - 8) 1-2' chop 9) 6100# 10) n/a 11) ? 12) - New Baja 1) 2003 Baja 36 Outlaw 2) 2x525EFI 3) Bravo XZ 1.5 4) Bravo 1 26" 4 blade 5) 4800 6) 76 in FW (TBD in Salt) 7) - 8) TBD 9) 9300# 10) Out (will play with in soon) 11) ? 12) - |
2 Attachment(s)
1) 1998 232 boss, 23' 6"
2) single 454Mag, 385HP 3) B1 1.5 ratio 4) 3 blade 23P M/P stock then labbed (no diff in speed) Bronson Hill 5) 5100 rpms 6) best of 68 gps 7) Prop slip 0.081 8) light chop 9) 5100 lbs; 2 adults, gear, 40 gals gas 10) -- 11) Hook never checked 12) No pic 1) 2002 252 Islander 2) single carb 502, 470hp range I think 3) B1 1.5 ratio 4) Merc Bravo 1 24P 4 blade Not labbed and is the same as the MACH 24P 5) 5200 rpms 6) best of 66 gps 7) Prop slip Bravo 24P 0.16 or it's 23P 0.12 ? 8) light chop 9) 5500 lbs; 2 adults, 40 gals gas 10) -- 11) Hook is there 1/16th on the strakes 12) Have pic 3rd Prop) 25P M/P 4900RPMs 67 GPS! 13.4 slip |
1.2000 272
2.540 m-3 procharger 3.1.50 max machine worx xr 4.merc 4blade 30 p lab 5.5600 rpm's 6.85.1 gps (completely empty,10 gal gas) 83 any day of week w/3/4 tank,coolers,4 pass 7.1/8 inch hook |
1 1990 190DSR open bow
2. 4.3 carb, 175 3. Gen 1 A1, 1.84 4. Mirage 14x19 5. 5200 (tach is also 150RPM happy, so realistically 5050)(need a new one, as the engine top rpm is 4600) 6. 47.0 Radar, 47.1 GPS (3/8 tank, 2 people, one 110lb, one 160lb) 7 2800ish lb. 8 light chop 9 4.8% slip Dialed in pretty good for a 14 year old V6 with over 1000 hours, more than half at WOT. Also- Through Alisyn Type 1 drive oil I gained 2 MPH. Pic was 2 years ago running bad (4600) http://www.stupidfastboats.com/jvm1023.JPG |
ttt
| All times are GMT -5. The time now is 12:39 AM. |
