-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   32' caliber, best prop to use? (https://www.offshoreonly.com/forums/baja/90791-32-caliber-best-prop-use.html)
32 caliber 11-20-2004 04:51 PM
I just bought a 1995 caliber, could someone please give me advise on the best prop to use. It came with a 25 pitch mirage, how does this boat like 4 blade bravo 1 props? I had a hydromotive on my last boat a 92' 290. I use the boat on Lake Michigan only. I am looking for a good cruising prop more than top end. Please give me your opinions and what you currently are using. The engines are 454 EFI, 385 hp. thanks, Jim
SSComp 11-21-2004 01:48 PM
Re: 32' caliber, best prop to use?
Your set up is exactly like mine before I made upgrades. I liked the 25 Mirages (not plus) with this HP. Blowout was minimal out of the hole and in turns. Hydromotives did not give the intented results as it has too much stern lift.
If anything you may want to have your mirages cupped some more. I found this does help "bite" out of the hole etc.
You'll love this boat on the great lakes. MPI's have unmatched reliability.
liquid asset 11-21-2004 03:46 PM
I have hydro. 24's and cant bring myself to change because it handles good and runs 71 gps at over 5,000, 1995 with 502 efis
32 caliber 11-22-2004 05:23 PM
Most opinions so far i have got was to go with bravo 1's. I guess I will have to spend the cash and try those out. Thanks for the opinions!
SSComp 11-22-2004 06:06 PM
I sent you an e-mail but you may want to try your mirages for a summer. I had mine labbed and cupped not thinned for about $150 each at:
Airmarine
5638 S Central Ave
Chicago, IL 60638
(773) 582-0100
They actually will give you a computer printout of the touch points as well.
32 caliber 11-23-2004 06:28 AM
Bajalion, thanks for the info, I did not know of any place around Milwaukee that I could get my props labbed, I think I "will" take your advise and get my mirages cupped and labbed.
SSComp 11-23-2004 08:47 AM
Don't touch that set up until you can verify speed. If for real you have a great 32...don't touch it
32 caliber 11-23-2004 05:34 PM
ok, I will wait and try out the 25 standard mirages first before I go any further.
baja36ft 11-26-2004 10:08 AM
I had the same boat with the same power i put on a set of hydro's 24 pitch 4 blade
and turned the props in the boat rides great and top speed was 72mph THE x is
real low in that year so you need a stern lifting prop.bravo's didn't do it for me
it was real rough in the big chop!!!!!!!! and if you use 3 blades you will loose
you'r mid range IF YOU NEED PROP WORK CALL JULIE AT TROTTLE-UP
THEY DO GREAT WORK I CAN'T SAY THAT ENOUGH!!!!!!!!!!!
727-531-2255
SSComp 11-26-2004 11:24 AM
Anyone interested in 24 Hydromotives I have a set...Mint.
