Go Back  Offshoreonly.com > General Discussion > Beware and Stolen
would like thoughts on this >
Old 08-20-2015 | 10:16 AM
  #31
After four years I think you have no recourse.
thirdchildhood is offline
Old 08-20-2015 | 10:45 AM
  #32
If the shop is not too far away I would take the boat by them and ask what was their thinking when they mounted the boxes and cut the hole in the transom. was there a reason they felt for doing so.
buck35 is offline
Old 08-20-2015 | 11:14 AM
  #33
hullofjustis's Avatar
the transom being wet still I kind of agree with you however I have date documented pictures that the boat was just completed. mounting the extension boxes and drives to high that was there f up and paid them good money to mount them correctly and seal it properly
hullofjustis is offline
Old 08-20-2015 | 11:43 AM
  #34
I'm sorry for your headache, as I know even having it done right, there are still things to iron out and get running right.
Good luck with it, might have to just go with a raised hatch.... Call GlassDave!
frickstyle is offline
Old 08-20-2015 | 11:59 AM
  #35
jadento's Avatar
Let me see if I understand this correctly. The up 3" extension boxes is normally mounted at standard bravo drive height resulting in stock engine height but raising the X 3"s without redoing the transom? If that is the case, why would they have raised the motors? Also if they raised the motors on top of the 3" boxes...wouldn't this have raised the drive more than 3"s from stock? Anyhow, if i understand the idea wouldn't standard straight boxes lower your drive to a reasonable level? Maybe you could find someone that has straight boxes and wants the -3" ones for a trade.
I hope for your sake the shop is very understanding and feels responsible for a screw up. If not I dont think you have much recourse. Its just so crazy that a good shop with a good reputation and experience would mount a drive that high. Anyhow, waiting 4 years to complain about your drive height is gonna make a tough case to argue. Another thing is, I can't imagine spending that kind of money and having that major a job done without popping in the shop every week or two to check out progress. You might not have been able to tell the drive height thing, but you would have seen the partial transom thing. Had you caught that back then, you would not be in quite as much of a pickle.
Best of luck and keep us posted!
John
jadento is offline
