-   Black Thunder (https://www.offshoreonly.com/forums/black-thunder-109/)
-   -   BT Parts (https://www.offshoreonly.com/forums/black-thunder/275095-bt-parts.html)
CaptainLOTO 08-09-2012 08:05 PM
Thanks guys. I guess the 132 per tank is probably right. I had the fuel sending units changed and thought they were adjusted but when they showed half a tank and I put over 100 gals each tank I began to wonder. The mechanic is going to come out and make the change.
Coolerman...did you have time to find the numbers on the ones you put in?
boatme 08-10-2012 05:51 AM
I might have a set of the LED panel lights (for intereior cabin mood lighting ) that i would sell
CaptainLOTO 08-10-2012 04:01 PM
Thanks...for now the rope lights are still working. I'm trying to find the lenses for the courtesy lights under the bench seat in the cockpit.
