-   Black Thunder (https://www.offshoreonly.com/forums/black-thunder-109/)
-   -   43 Cabin Couch Question (https://www.offshoreonly.com/forums/black-thunder/348320-43-cabin-couch-question.html)
JBA 07-10-2017 11:16 PM
How do I remove the couch backs on an early 43? I feel like a fool because I cannot figure it out....
Coolerman 07-17-2017 10:15 AM
There are probably some screws that are covered up by either carpet, or other pieces of white vinyl covering.
endeavor1 07-17-2017 05:23 PM
^^^ Sax, this is BT cabin talk not bilge talk. Not sure if you've ever been in your cabin:flag::angry-smiley-038:
TxHawk 07-19-2017 02:27 PM
Rooms to Go stocks these replacements no?
splashandburn 08-08-2017 07:20 AM
i finally figured out how to get mine off. You have to remove the light panel above the couches and then a few wood trim pieces that are screwed in. Once they're out you'll see 10 or so 3/8" nuts. Remove those and the couch back insert will come out - but only the insert not the whole back. The backs are actually fiberglassed right into the side of the hull. The only way they're coming out is of you cut the fiberglass out. Not sure why they permanently mounted them . . .
JBA 09-18-2017 09:37 PM
Turns out that it was glassed in with 0 way to remove without cutting it out.... I somehow got a hold of Bob Jenkins (Great Guy that took time out of his day to talk old boats with me) He had sad that they never thought about the cabin seats coming back out because they had used top quality materials.
