Trailer adjustments for new boat
I have made several posts about possibly getting a new to me 29 Fountain next weekend july 11th. I have been doing my research and cant seem to find a great answer. I would be purchasing the boat by itself and then I have a trailer lined up to purchase separately. The 2 boats I have owned both came with trailers so I have never messed with them. Is there potential or a good chance that I will have to mess with the bunks on the trailer to get the boat sitting right for transport back home? If so, does anyone have any guides on how to set these up? This is a 29 fountain with a single step, single engine. The trailer will be a triple axle, not sure on brand at the moment, still waiting to hear back on that, but it is meant for a V bottom.
measure the length and depth of the step and add some wood on top of the rear bunk to support it, maybe wrap it in outdoor carpet, I wouldn't haul a step hull on a flat trailer, jmo
Originally Posted by DallasBAJA
(Post 4746313)
Originally Posted by jtbooten
(Post 4746336)
IMO, you may want to consider a tandem axel trailer for turning in tight areas. I have a 32 with a tandem trailer. I don’t like the bind I put the front axel and tires when turning in tight areas. I defiantly don’t want a third axel.
Does anyone know the height of the step on a 2002 29 fountain fever single step? I could for sure bring some tools, wood, and outdoor carpet to make the haul home if needed, It looks like possibly a 2x4 would do the trick, but would like to have some decent measurements to pack the stuff now since the hardware stores are on the other side of the lake from where the boat/trailer are. |
Do you know what the trailer you are going to put the boat on is currently set up for? That would be the first thing I would try to find out, that will put you in the ballpark, at least give you an idea of whether or not it's even do able. That being said just because the trailer is setup for a similar hull doesn't really mean jack. Second and just as important, is the trailer even adjustable.? If the trailer is adjustable you can try to get it close by measuring the spacing on the bunks. Then you could put the boat on the trailer and get a floor jack (two is better), a mallet and an impact to loosen up the bolts. Loosen up each bunk on at a time and move them to the correct spot, jack it up till it's tight against the boat and tighten up the bolts. This is how I put my boat on a new trailer that I built, but I hung the boat and adjusted the bunks while sliding around on a creeper underneath it. A creeper really helped. If the trailer isn't adjustable your pretty limited, your essentially shimming the boat w wood which is not great.
Months have passed since the o.p. first posted...I wonder what he did?
Trailering is one thing...long-term storage on a trailer that doesn't fit the hull nearly-to-perfection is bad, bad, BAD. IMHO, the $$$ saved from purchasing a used trailer vs just buying one MADE for the boat is dollars wasted. For a 29' boat probably only a couple of thousand bucks saved...? |
Haha, didn't realize it was an old post. I totally agree with you, nice / correct trailer is often overlooked.
Waited a year until COVID was sort of figured out and my daughter was a little older. Boat was still available and ended up buying a brand new aluminum trailer custom fit for it. Worked out really nice.
https://cimg5.ibsrv.net/gimg/www.off...67cb55129.jpeg |
Beautiful boat! We bought a 1987 Formula 242 as our first boat but a Fountain is definitely in my future.
| All times are GMT -5. The time now is 02:35 PM. |
