-   Carrera (https://www.offshoreonly.com/forums/carrera-235/)
-   -   24 carrera/ scorpion (https://www.offshoreonly.com/forums/carrera/216524-24-carrera-scorpion.html)
T-Mone 09-09-2009 10:39 AM
what do you think would be a good x dimension for a 24' w bravo set up?
T-Mone 09-09-2009 05:58 PM
Anyone?
rchevelle71 09-09-2009 08:41 PM
Wouldnt it be similar to your Pantera??
T-Mone 09-10-2009 05:48 AM
mine now is high the prop shaft is 2 1/2 below bottom, I was wondering if someone has changed there x from the original trs height. Not sure is what i have now is to high.
excalibur1979 09-11-2009 11:54 AM
I did my 24 excalibur which is the same hull at 17.5 x dimension with a bravo 454 set up. Still could run a 3 blade mirage.
no limits 09-12-2009 09:19 AM
Frank's Marine race boat had his high. I think he was around 18 w/no box. He might have had the hole cut at 19 because I remember seeing a 1" spacer on drive to lower it.
JCG 04-05-2010 08:26 PM
Whoever made this guess is almost correct. The Frank's Marine Scorpion A-78, X Dimension was 19 1/4" high, because the bottom hull had a delta pad. That height was perfect for calm water. I had a drive with a 1" spacer for rough water conditions. Both set-ups were excellent for each condition.
I recommend for a pleasure boat with a delta pad and regular Bravo drive, an 18 1/2" height.
-Frank
