-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   Finshing projects on new ZT 280 (https://www.offshoreonly.com/forums/checkmate/130123-finshing-projects-new-zt-280-a.html)
Magic Medicine 05-14-2006 03:51 PM
3 Attachment(s)
I am finishing some of the projects on my new to me ZT 280. Here are a couple of the pics of my progress on the projects. I installed a Liverosi GPS speedo and oil temp guauge. I am also in the process of installing dual ram add on hydraulic steering. I hope to be done with that next weekend. What a pain!
Magic Medicine 05-14-2006 04:03 PM
Re: Finshing projects on new ZT 280
2 Attachment(s)
Here is the recall switch for the GPS and the oil temp guage. I will be glad when I finish up the steering and install the new oil filter bracket that I bought form Trick Marine. Fred is make some brackets with 1/8" NPT fitting so the oil temp sensor plugs right in. Enougth work I need to hit the lake in a bad way! :evilb: :D :drink:
CHECKMATE ZT 280 05-14-2006 11:36 PM
Looks good andy,have you been out with the new boat yet? the weather is still cold and rainy around here so i haven't been out . Robin
Magic Medicine 05-15-2006 05:23 PM
I ams till putting the finishing touches on the steering, so I have only been out once. The weather has been crappy here too, so I don't feel bad about not having the boat done. I am hoping to wrap the steering up next Saturday and get her wet.
Magic Medicine 06-03-2006 07:36 AM
Well finally got everything wrapped up with the projects. Last night I ran the Check on Lake Michigan. I ran 70 and change not quite 71 on the GPS with 3/4 tank of fuel with 4 big guys in the boat and 2 ft chop. I think I will be able to run 73 with a light load. I am very happy because 70 all day long in the number I was hoping for! :drink: :evilb:
RJBBC 06-04-2006 06:15 AM
What do you think of the full hydraulic steering? Does the boat feel more stable? We are thinking of increasing our HP next year to around 500 and are currently not budgeting for hydraulic steering. Is this a mistake?
Magic Medicine 06-04-2006 07:15 AM
I have a dual ram add-on system. It is well work the money. No more slop in the wheel and way more stable at high speeds. I only drove the boat once before I installed it, but I made a huge difference. I would go to add on system you can always upgrade when you have the $$$. Call me if you want before the install, I will walk you through it. I made a mistake that has cost me what I could have went to full hydraulic system. Live and learn!
RJBBC 06-04-2006 03:03 PM
What is the difference between full hydraulic and dual ram add-on steering systems?
Magic Medicine 06-04-2006 08:15 PM
Full hydralic on all the way to the helm, steering wheel. They eliminate the steering cable and other steering components near the bell housing. An add on system ties into the current steering system and is considerable cheaper.
