-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   New Livorsi Gages Installed!! (https://www.offshoreonly.com/forums/checkmate/156318-new-livorsi-gages-installed.html)
JUPITER PULSARE 04-19-2007 04:22 PM
3 Attachment(s)
Finally finished installing my new gages, stereo and Jackplate switch. Tim Parsons did an outstanding job rewiring behind the dash!! If anyone needs custom work done in the Palm Beach area I can put you in touch with Timmy!!
JUPITER PULSARE 04-19-2007 04:28 PM
3 Attachment(s)
some pictures from the behind the dash. Big Improvement over what it used to look like!! Thanks Tim!!!!
Magic Medicine 04-19-2007 07:55 PM
Looks great! I really like that metal flake. Checkmate leaves alot on the table when it comes to rigging.
blacktruck 07-08-2007 05:50 PM
Awesome. Great Livorsi dials. love the jackplate switch location. Mine is on the left by the key. Do you run your pulsare in the ocean? I'm worried about running mine in the ocean it is freshwater only so far and its mint. Worried the salt is gonna ruin it.
JUPITER PULSARE 07-17-2007 11:03 AM
I run the ocean every weekend. I've been saltwater boating my entire life and have never experienced a breakdown due to saltwater. You can protect your motor by removing the Cowl and spraying the motor down with Boshield or Marine CRC. The saltwater will not effect the boat at all. My Jackplate switch was also on the left side. When I removed the original switch I filled the hole with a overheat warning lamp.
