-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   Engine Choices...... (https://www.offshoreonly.com/forums/checkmate/162572-engine-choices.html)
checkmate DOH!! 07-03-2007 11:19 PM
hi all----just recently picked up a very super clean original owner 17' Checkmate Diplomat bowrider. Really nice boat----has the original MCM 470 3.7L with an Alpha 1 outdrive----runs great but also wondering what my future options are if i want to swap out for bigger and badder. I have access to a still-in-the-crate 1987 GM Targetmaster 350 engine that i believe was slated to be installed into a ski boat and never was----dont ask!!!----or possibly a nice fully dressed 4.3L that i could drop in--someone in the local want ads was selling one from a 1988 boat that was up for maybe 1300 bucks or so??--anyone have any info concerning the fit and limitations on power/hull withstanding if i want to do a swap??? im sure for at least this year and possibly next the original 4cyl will be in there but any input on my options would be appreciated----thanks
Magic Medicine 07-04-2007 11:17 AM
I would build a healthy small block. 350, 383. Keep the stock engine when it is time to resell. Small blocks are pretty cheap to build.
checkmate DOH!! 07-05-2007 09:25 AM
yeah ive got that brand new motor to build up some or my buddy wants me to take the engine from my 4speed 78 nova and put it in there----that i built 2 years ago and it is still real fresh -----nice cam not real lumpy still idles ok----30 over on the bore----10 to 1 compression and an edelbrock dual plane manifold rpm air gap----ive heard you ned to run a single plane on boats though. is that true?? also heard too much valve timing overlap with a lumpy idle cam is no good either...feedback?? but as far as the hull and size of the boat 17' i should have no problem with the swap?? thanks for the reply :D
Magic Medicine 07-05-2007 04:55 PM
Do not put a car motor in the boat. It will not last, boat motors goes through way more stress than a car motor.
checkmate DOH!! 07-07-2007 05:10 AM
yeah thats why the 350 in the nova is staying in the nova----but i need to run some numbers and do a little research on the 1987 350 targetmaster still in the crate that i have----according to my father it was installed in a boat application but taken out even before any hours were accrued----???---maybe just someone opted for the upsize right away?? anyhow if i get all the block numbers and stuff how could i run them to find out origin and if this is truly a marine engine?? thanks for the info...
