Tilt and engine break up
Hey have any of you guys had this problem? I have a 92 Persuader 234BR w/ 454 mag and bravo I, which I just had rebuilt and installed. Now at rpms above 3500 when I trim up/down the engine breaks up while button is depressed.:angry-smiley-055: I noticed the volt meter also drops 1-2 volts. It seems to be worse on trim up and at higher RPMs.
Anyone have any ideas? |
Check your battery lead at starter may be loose, check your grounds.
Jim |
I will check that Sat. and see.
Problem Solved
I jumped from +bat to + coil and stumble went away. I guess the old long wire from key to coil is sucking up volts/amps. I plan to install a relay between the key and coil near coil to get good strong 12V current. Lot easier than replacing all that wire.
| All times are GMT -5. The time now is 10:54 PM. |
