-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   Throttle trim??? (https://www.offshoreonly.com/forums/checkmate/182218-throttle-trim.html)
nsreeve 03-15-2008 08:11 PM
Throttle trim???
What kind of throttle trim switch does everybody recommend, and where can I get it. I see livorsi has one for $100...damn.. I'm tired of the steering wheel toggles which are hard to get to since you are usually steering from the top of the wheel
Elite Marine 03-15-2008 08:26 PM
If I can help, let me know. $ 100.00 is probably list.
Email me at [email protected]
www.elitemarineonline.com
Kirk
nocigarette 03-16-2008 06:15 AM
Look around a bit....I bought one off ebay for 30.00 and it was brand new.
Griswald 03-26-2008 09:48 AM
Check Dana Marine! I just picked up one on BlowOut Special for $19.95.
click here
alliedtf1 07-04-2008 04:45 AM
Trim Switch Fix
I can tell you a trick on how to set up your trim switches on the steering wheel. Instead of having the switches mounted so that they are flipped up and down, which is backwards when you turn the wheel. Mount them so that you push them in (toward the wheel center) they trim down and out (toward the edge of the wheel) they then trim up. This way no matter what postion the wheel is in, in is down and out is up. Give it a try.
