Looking at 89 251 Convincor,Look for???
I am going to look at a 89 251 Checkmate Convincor on Tuesday. It is obviously snowing here and wont be able to test drive the boat. Is there anything that is a common problem with this boat that I should look for? I have been doing a little bit of research and havent found any specific issues yet but... I have built a couple boats so i have quite a bit of knowledge but would like you guys input.:party-smiley-004:
Thats a good boat, their are no problem areas to look at unless it was not taken care of. Problems that were created by owner neglect. I would not buy anything I could not water test thats risky.
I had a 1999 checkmate 251, and many of my friends have had them. Good running boat, however if were buying in todays market, I would want to run the boat. The least I would do if I were seriously going to purchase is run the boat on the muffs and do a compression test. If everything checks out then winterize it. Only takes a few minutes and at least you know there aren't any hidden problems. Just my 2 cents. Lots of deals around, but you don[t want to buy a headache or find out something bad come spring time.
floor rot, soft spots will show that...stringers, need to look closely at those...under engine especiallly..transome can be a issue as well...not as common as the floor stringers...have one for sale also...Rob
My first brand new boat was a 1989 251 with a 330/Bravo 1. I loved the boat but within 10 years the floor had issues on the starboard side so I replaced the entire floor better than new. The following spring the gas tank cracked.......new floor round 2.
have the same boat .love it, rides great , look at the wood at the sundeck.
| All times are GMT -5. The time now is 06:00 PM. |
