-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   Checkmate 270 Convincor expectations (https://www.offshoreonly.com/forums/checkmate/336650-checkmate-270-convincor-expectations.html)
Jonesyfxr 04-22-2016 07:48 AM
I'm looking for any and all information on a 270 Convincor. I'm wondering how well it rides, handles, and how well the deck and cuddy is configured? Would this be a decent intro into the powerboat scene? Would this be a decent boat to take out, say five people for a ride to the local hangout?
Any input is appreciated.
Knot 4 Me 04-22-2016 11:12 AM
The biggest issue will be porpoise at cruise unless the boat has K-planes or similar style tabs. That is my experience with the 259/270. They have a nice layout in terms of cockpit and cabin for that size boat. The glass/gel work is second to none. 5 people to the local hangout will not be a problem.
Gimme Fuel 04-22-2016 12:53 PM
The porpoise on my 253 was mostly eliminated at all but barely on plane speeds by running a hydromotive intimidator prop. I never use my tabs. run it above 35 mph and no worries.
People run a lot of bravo one props on them, personally I hated every one I tried. Rev 4 prop was fast but had even worse handling and bow steer.
Jonesyfxr 04-22-2016 01:30 PM
And yet again the OSO members come through....thanks for the insight guys!!
AE Stream 04-24-2016 09:30 PM
Jonesy take a look at the 283/300 checkmates as well. If you can make it work size wise. It is not that much heavier than the 259 but is a much bigger boat. With a single stock hp500 you will see high 60s. You can pull with a half ton pick up. It does not have the mid range porpoise issue. And it is alot bigger boat, it will span the waves on Erie and ontario and be a much more comfortable ride. There is a lot of room on that boat for its size, trust me it was hard to replace. Good luck with your search. I owned a 283 and rode in a few 25s. if you have questions I'll shoot you my number
RGPIII 04-24-2016 09:59 PM
I love my 270. With a little seat time you learn to get rid of the porposing very quickly with dropping the tabs or trimming down some.
82predictor 04-24-2016 11:22 PM
Jeremy is right about the 283/300 being the better choice if you can go that large (not sure if you are trying to stay in a certain size). Find one with a single (twins the engine compartment is very tight). The 283/300 will have more cockpit space and cabin room and is a big boat for its size with lots of freeboard. If you can find a 300 with the full notch transom that is supposed to be good for another 3-4mph.
I had a 253 (almost same as 270) for 5 years. It was a great boat! The porpoise on mine could be controlled with just the trim if 2 people were in the boat (or the throttle) with more people in the boat you had to run a small amount of tab at slower speeds (under 40mph). I had a 502mag and it would run 64-65 any day with 4 people and fuel. The only thing I wish it had (besides more hp) was k planes and hydraulic steering. The gel coat and mold work on checkmates is amazing with not a ripple down the sides and they are built solid. The rigging leaves a little to be desired but is expected at the price point.
One thing to consider between the 253/270 and the 283/300 is that 253/270 boats are liner boats. Not sure what year the 283/300 changed to liner but they had the wood floor with carpet into much later years than the 253/270.
Let me know if you want to talk about them and if you are looking at a specific one, I would spend a little extra coin and get the 283/300 like Jeremy said if you can for going on the big lake. Jeremy's ran pretty good with no tabs and the throttle pinned :evilb:
BIGBREW 04-25-2016 07:28 AM
What are you guys running for props? When I had my 270 I also saw the porpoise issue, I was running a Bravo 1 at the time. My boat had a 1.65 drive and I was running a labbed 28. Bravo is a bow lifter. Buddy of mine had a 28.5 Hydromotive that he let me try, I fell in love with it right away, took a lot of the porpoise away (Hydromotive is a stern lifter) my wife even noticed a difference in the way the boat rode. You have to use more trim with the Hydro but I loved the way my 270 rode with the Hydro prop on there. One quirk about the Hydro prop, when I would power down it would cavitate, I would have to come to almost a complete stop and power back up again. I took the large round anode (cavitation plate) out, prop never lost bite again, actually I think it pulled a couple hundred RPM out at wot.
RGPIII 06-15-2016 09:36 PM
I have run a 23 rev 4 which was terrible with proposing, I switched to a bravo 1 26p which runs awesome on the boat. I just bought a 25 hydromotive that i've run one time so far. i will need some more seat time with it to see how it compares to the bravo.
uluru 02-21-2017 08:48 AM
Anyone know anything about this Checkmate 270 Convincor advertised on Kijiji Ad# 1232618104 from Quebec
I don't now how to post the link
