Looking forward to the results. I feel like that's an area that most often gets over looked is the fuel delivery support. Not just the car or injectors etc.... But the actual lines and fittings coming from the fuel tank itself. You can only pull x amount through a certain diameter fitting and tube setup regardless of the pumps and other items installed.
Originally Posted by CharlieWhiskey85
(Post 4823613)
It was suggested to me to run 1/2" inside the tank and to the fuel pump. And I'm only projected to make 550 HP. (carbed)
| All times are GMT -5. The time now is 03:07 PM. |
