-   Chris Craft (https://www.offshoreonly.com/forums/chris-craft-155/)
-   -   Northstar Ignition Upgrade (https://www.offshoreonly.com/forums/chris-craft/212220-northstar-ignition-upgrade.html)
vtx1800sba 07-02-2009 06:13 PM
Guys and gals, I'm looking at a 1990 Chris Craft 245ltd. Bone stock. Nice boat. I found another out east that has added Northstar Ignition. Is this a common upgrade? Difficulty? More horsepower? Better fuel economy? Please advise.
tinman565 07-06-2009 03:29 PM
I dont know about the Northstar upgrade (may not even be an upgrade...lol). I own an 89 245 Limited...and LOVE it !!. Got any pics of the one your interested in ? Any info on it ? Price ? Just comparing it to mine.
vtx1800sba 07-06-2009 04:17 PM
I've got a few images of it. will send them out soon. in the midst of striking a deal with the owner. will keep you advised.
tinman565 07-06-2009 05:02 PM
sweet...you can email me at tinman467 @ aol . com
Dan245LTD 07-07-2009 09:36 AM
I have owned a 1988 Chriscraft 245 LTD for about twelve years now. This boat has been an excellent weekend getaway stress relief. You will find that these boats will handle rough water very well. I use to boat along north shore of Lake Erie in Canada with mine. The Cuddy Cabin is great for overnight use too, so that is a positive.
The other thing is that the boat is easy to trailer, launch & recover at the ramp, than larger boats.
My boat has the OMC 460Ford King Cobra sterndrive, I would
recommend that you stick with Mercuiser/Chev combination, as parts are harder to find with OMC.
I have been fortunate in not having mechanical problems that I have heard others have had with OMC.
Does your boat have tru transom exhaust?
Good Luck
vtx1800sba 07-07-2009 07:44 PM
Good Luck
Thanks for the great note on your 245! To answer your question, the boat I am considering does not have through hull exhaust. But the current owner does have a Corsa Thru-hull kit that he's never installed. Said he'd give me a good deal on it. As we use our current boat's swim platform I would likely install a side exhaust or the kids would be sick of the exhaust fumes, or I'd be hitting the captain's call switch quite a bit.
Dan245LTD 07-07-2009 08:42 PM
I often wondered whether the Thru Transom exhaust was a factory installed option, or was done by the previous owner. I would assume it was done after purchase. The exhaust flapper outlets are below the swim deck on my boat. I don't have any young children so never had concerns regarding exhaust fumes.
I have never heard of Northstar Ignition System. I had to purchase an Accel Marine distributor for the 460Ford as previous owner had installed automotive unit complete with vacuum advance. Not a good move as distributor was full of rust. I would suggest you get a spare distributor and rotor for your boat. I always carry a spare in small tool box on boat for emergency purposes. Better to be prepared than standed on large Lake.
I would also suggest doing an engine compression test before you make this purchase, or get a mechanic to do it. Might be worth some piece of mind before finalizing a deal.
vtx1800sba 07-09-2009 04:54 AM
Dan, all sound advice. Thank you.
I believe the Corsa unit he has is for thru hull below swim platform. Far as the ignition system, I spelled it wrong; it should be Norstar. I found a guy in Grand Island New York that has one on his 245. Said it came that way from the factory.
Dan245LTD 07-09-2009 07:46 AM
You never mentioned if this boat had the 460Ford King Cobra or the Mercruiser /Chev sterndrive. I have the Chriscraft Sales brochure for 1988. Very interesting reading shows all the model boats for that year. The 245 Limited was available with Small Block 350 or Big Block 454 engines.
Does this boat your considering, have Trim Tabs mounted on the hull? Mine has them installed, but of course may have been added by previous owner or a factory added option.
The only items I have replaced were the Distributor as I stated before, and I replaced the Exhaust Manifolds. I had one cracked manifold when I purchased the boat, probably caused by not winterizing it correctly. I installed Cast Aluminum Kodiak Manifolds as a replacement. I know previous owner installed Edelbrock Torquer Intake Manifold and roller rocker arms. Must have been trying to up the performance.
I am Diesel Engine Tech/Mechanic, so only do preventative maintenance. Don't want to spend time playing with engines, since I do that for living. If it isn't broken don't touch it is my motto!!
Full Force 07-10-2009 05:40 AM
I used to have a 88 245, I loved it also, but I am Erie and do alot of overnighting so I needed something that would do 3-5 footers easily without going 10 mph, although a great rough water boat, I had mine in 5-6 footers a few times, I had the 350 small block but built it to run 53 on gps, stock with small block runs about 43-44, I would go for a Merc BBC one.
Here are a couple pics of mine, I kinda miss it, had a TON of fun with it!!
http://i36.photobucket.com/albums/e4...g/100B0922.jpg
http://i36.photobucket.com/albums/e4...g/116_2698.jpg
Dan245LTD 07-10-2009 06:22 AM
You mentioned that your boating was on Lake Erie with 245LTD. I use to boat extensively on North Shore Canadian side with my boat. I already mentioned that these boats handled rough water quite well. I was asking him if the boat he was considering had Mercruiser/Chev or OMC King Cobra sterndrive. I told him that I had the 460Ford King Cobra, and well it has been good that he should look for Mercruiser set up on this boat. Since OMC's demise, locating parts will become problematic & even more so with passage of time. So far I have never had major problems $$$, but is certainly a valid consideration.
I would think you had more than adequate performance with
small block Chev in that hull.
tinman565 07-10-2009 07:08 PM
Our 245 has 4" thru hulls (shotguns) under the swim platform as well. It had a stock BBC mercruiser/ Bravo 1 in it when we got it. I have since installed a slightly warmed up 502 Mag. So far without touching the timing, or jetting the carb...we got it to go 65.3 mph on the GPS with two 240 lb guys in it and a half tank of fuel. I think if I finally figure out this prop voo-doo stuff, and tweak the motor a little...I think itll run 67. It starts to dance around a little at that speed...but its alot of fun. Kids love the big sun deck on the back, and the factory built in swim platform is nice. Cant really complain...wife even said it was the best family purchase we ever made.
Full Force 07-10-2009 07:18 PM
The small block was weak when it started out, hard to plane, but I also always had a weekends gear and 3-5 people on it, it was better after engine upgrades but the bigger propping then made it still hard to plane, in my opinion, any performance boat should have BBC's
vtx1800sba 07-11-2009 11:43 AM
The 245 I am interested in had the 7.4 king cobra (460 cu in). I believe it has trim tabs. have to look at the images again.
Full Force 07-11-2009 12:14 PM
Everyone seems to be afraid of the 460/Cobra stuff, I am a Ford guy and the 460 is a great engine, and the drive, well... from what I know about the Cobra they tend to break less then a Bravo, parts are more expensive but if they don't break then whats it matter?
TomZ 07-12-2009 10:41 PM
460 Ford equals small block Chevy characteristics but on a much bigger scale... very good engine! If you're going to keep it mostly stock, then this is a very good, strong platform. Marine performance parts may be harder to find though and more expensive.
The 245 LTD is a great boat! Good luck on the negotiations.
Post pics!!!
Dan245LTD 07-13-2009 07:52 AM
The Ford 460 engine has been very reliable over the years I have owned it, and the King Cobra is a strong stout drive. You may have to jump thru a few extra hoops to get some parts is all I am saying. Do your regular preventative maintenance, oil changes in drive and engine, plus your filters, tune ups and you will be fine. With the internet and forums like this you for advice you won't have a problem.
