-   Chris Craft (https://www.offshoreonly.com/forums/chris-craft-155/)
-   -   Dual Batteries (https://www.offshoreonly.com/forums/chris-craft/307115-dual-batteries.html)
SabrToothSqrl 01-06-2014 02:44 PM
Dual Batteries
Ok, so I've installed a huge ass stereo... and the wiring for dual batteries. (and new braces)
the idea is to have 2 fully charged batteries ready
run on that
when we stop, switch to Batt 2 and play the radio all day with no fear of a dead battery
then, using Batt 1, start the engine. then switch back to 'both' while it's running to charge both.
so, my question is... Can I use 1 starter and 1 deep cycle battery? will the boat charge both just fine?
Or do I need two identical batteries? They will both be new this spring, just need to know if I can mix the types...
Katanna 01-06-2014 04:52 PM
You can mix both. Instead of a switch, you can wire in a solenoid that brings your stereo battery into the charging circuit only when the engine is running. When you shut it off the battery is seperated. I have done it with a battery switch, yes and forgot to switch it=two dead batterys.
SabrToothSqrl 01-07-2014 06:52 AM
that's an interesting proposition. I got the old school battery switch for free.
how would I wire your setup?
the leads for the amps are on Batt2, but to turn the radio on/off needs power at the 'boat' connection.
ALL_IN! 01-07-2014 07:37 AM
Go to Blue Sea site, and take a look at schematics for their automatic charging relay (ACR). I added a house battery (deep cycle) and ACR to my boat this past summer, and it has worked great.
NOTE: I've got a twin engine with a starting battery on each engine - one of those batteries was dual duty house and start battery (stupid design).
SabrToothSqrl 01-07-2014 09:26 AM
Very cool toys. Sadly my 1990 boat was single engine, single battery, so it was never really setup for 'house' power... no switch panel no nothing. everything comes from one battery connection.
ALL_IN! 01-08-2014 07:23 AM
That doesn't matter. Like I said, take a look a the schematics.
You can add a "house" battery to your rig with the Blue Sea Add a Battery kit. It will allow your starting battery to be used for its purpose, then have a house battery for your stereo. When running down your body of water, the alternator will charge your starting battery - but once it reaches adequate charge, the ACR switch over to charge your house battery. Once you are at your float/raft/anchor spot, the "house" battery would be used and isolated from your starting battery (cheap insurance) - therefore, no discharge of your starting battery while playing your music. Of course, a switch will work for this - however, the ACR makes it automatic.
I believe the kit is about $100. Mine was a little more elaborate with twins, but concept is same. I never touch my battery switches unless I'm wanting to turn all systems off (starting and house).
SabrToothSqrl 01-08-2014 10:59 AM
very cool. I will look into it
thanks!
