39 center console conversion
I picked up a 390 stinger a few years ago to chop up and build a no frills fishing boat for offshore tournaments. I didn’t document a lot of details but wanted to post what I had.
https://cimg2.ibsrv.net/gimg/www.off...46e2d8308.jpeg https://cimg3.ibsrv.net/gimg/www.off...a897d1f931.png https://cimg4.ibsrv.net/gimg/www.off...794758bbea.png you guys looking to maintain/restore boats of this era can pretty much assume All the wood is rotted. However the original lamination was quite good. |
https://cimg4.ibsrv.net/gimg/www.off...25c44136d2.png
https://cimg6.ibsrv.net/gimg/www.off...8339b158e5.png 300 gal fuel tank https://cimg7.ibsrv.net/gimg/www.off...be98fcf829.png 4” hollow glass stringers filled with 4# foam |
https://cimg0.ibsrv.net/gimg/www.off...7abc7f80ca.png
https://cimg4.ibsrv.net/gimg/www.off...38540c0446.png https://cimg5.ibsrv.net/gimg/www.off...98309d923f.png https://cimg7.ibsrv.net/gimg/www.off...d42e091248.png https://cimg9.ibsrv.net/gimg/www.off...162778819b.png One piece deck with hatch receivers. |
How did you go about building your hollow stringers and then foam filling them?
Pulled them from a 30’ by 31/2” plug.
2” holesaw cuts in stringers/bulkheads and poured 2 part foam. Just be sure you have exit holes. also filled the the side cavities in stringer grid that weren’t going to have a hatch access. Same procedure, cut two holes, mix and pour. Completed hull with console w/leaning post live well weighted in at 6115#’s. Was hoping it substantially lighten up the boat but by the time you add diesels and heavy duty drives the boats probably about where it started on weight. |
https://cimg4.ibsrv.net/gimg/www.off...55d776771b.png
Installing new deck |
https://cimg9.ibsrv.net/gimg/www.off...ee7fe3fcf9.png
https://cimg1.ibsrv.net/gimg/www.off...4e9d649b58.png There were two other hulls in this shop at the time, one was a 38 scarab with a mocked up top cap intended for a one off. The one off cap was used as a mould to build caps for all the hulls and sold to a fourth guy who glassed to a hawk 40. Sorry for the pic quality, some of these are pictures of pics stuck in my previous phone. |
https://cimg6.ibsrv.net/gimg/www.off...e166e6e1a8.png
Cut the cap at the transom and sides to fit the bigger hull. |
