rocker switch question 79 mistress >
Old 07-26-2005, 08:18 PM
ratman's Avatar
Default rocker switch question 79 mistress
on the dash i have six rocker switches what should each one operate? its a 79 mistress. thx in advance for any info, ratman
ratman is offline
Old 07-27-2005, 12:26 AM
ratman's Avatar
Default Re: rocker switch question 79 mistress
ttt, anyone help me out ratman
ratman is offline
Old 07-27-2005, 06:41 AM
Crazyhorse's Avatar
Doug with the big red Top Gun might be able to help you.
Otherwise you may be able to figure it out by elimination. Does the Mistress have starter buttons like the flat-decks or is the starter-engage built into the keyswitch?
You should have one for panel lights, one for nav lights, one (possibly two) for bilge pump(s), cabin lights, cockpit lights, one or more for accessories. I've never been in a Mistress and am just guessing from the flat-deck layout.
Another guy that may be able to help is cashbrain out of Chicago. He's got a Mistress.
Crazyhorse is offline
Old 07-27-2005, 09:44 AM
Monty's Avatar
I have a 85 Mistress. Are you referring to the switch panel to the right or left of the steering wheel?
On mine the left panel has the ignition on/off key switch, push button starter switches, a parallel switch, 2 bilge pump switches, 2 electric choke switches, and an accesory outlet (cigarette lighter).
The right panel has the nav light switch, panel light switch, blower switch , accesory switch, and cabin light switch.
Monty is offline
Old 07-27-2005, 05:27 PM
ratman's Avatar
monty, im refering to the switch on the right in front of the sticks..the 6 rocker switches for trim and the drives? what switch does what. thx, ratman
ratman is offline
Old 07-27-2005, 05:29 PM
ratman's Avatar
monty can you take a close up pic of your three panels so i can read the letter that tells what each switch is? thx a lot for you help im almost ready to dip it just need to get the electrical figured out now. ratman
ratman is offline
Old 07-28-2005, 08:48 AM
Monty's Avatar
I'll send you some pics on Monday.
Monty is offline
Old 07-28-2005, 09:20 AM
ernie davis's Avatar
Uhhhh.....just a guess here.....6 swithchs.......kinda look like where the
Left and Right drive trim (2) , Left and Right tabs (2), middle ones for both at the same time (2).
ernie davis is offline
Old 07-28-2005, 09:35 AM
Monty's Avatar
Yeah what he said...the top 3 are drive, the bottom 3 are tabs.
Monty is offline
Old 07-28-2005, 11:23 AM
NJgr8ful's Avatar
yup, top 3 drives / bottom 3 tabs. Center operates 'both' for each
NJgr8ful is offline
Quick Reply: rocker switch question 79 mistress
