1990 Bullet
I have always liked the way a bullet looks, but have no knowledge of them. I would like to know the pros and cons with this boat. Ride, handling and such. I figures I would ask since I know no one with a Bullet. Thanks alot.
Re: 1990 Bullet
Never had one, but have spent some time on Birdog's bullet and it was an awesome boat. They are solids boats you wont find a 31 foot boat that can handle the water like it does. I'd love to find one myself. I am sure that OldSchool and Birdog will chime in and can answer any questions you may have!!
Re: 1990 Bullet
Thanks alot, like I said before I have always liked the way the Bullets have presented theirselves.
Re: 1990 Bullet
I have always loved the look of the bullet and the way they handle rough water while only being 31 feet which makes it easier to trialer and manuever. All in all they are great boats.
Re: 1990 Bullet
The bullet is a HUGE Heavy 31 footer. You wont find anything in that size range any tougher. Typical Cigarette Quality of Construction. Takes some HP to move them tho..... :D
Re: 1990 Bullet
Re: 1990 Bullet
Twin 550's will get you upper 70"s.
Very unique look and very heavy. |
Re: 1990 Bullet
Birdog/Brad are absolutely correct. The 1st Bullet I bought is an '88 purchased in an estate sale back in '94. It needed some work but nothing major. 2 engines & r&r transom assy to replace steering parts etc. I was in heaven the 1st time out. Felt like I was riding on air in 2 foot swells.
Still have the '88 & bought another '89 Bullet needed "everything". The 2 year restoration process was rewarding. ( For Sale). The '88 has approx 650hp & will put ya back in the bolster. The '89 has stock 365 mags...what a huge difference. These boats are in the 10,000 lb range & do require hp's to move it. My '89 is into the hi 70's low 80's pending chop. The '89 is hi 50's-low 60's. These boats have no problem with rough water at all !!!! The cabin layout is mint & can easily sleep 4 people. With the enclosed head it pleases the girlfriends/wifes peacefully. Although it is kind of small it serves its purpose. Not to mention the "BJ" chair". The engine compartment is awesome, the back of the rear bench seat is part of the hatch. Very accessible. The only bad thing I can think of is the design of the upholstery bases. They have a tendency to rot out. An older non restored Bullet will will need reconstruction of the wood frame for the engine hatch/back seat. The bottom base of the rear bench (between battery switch panel) rests on the cockpit floor & will wick water. As well as the very top of the bench base. When these were made, the ends of the plywood were not beveled to allow fiberglass to correctly bond leaving air gaps...thus water seepage to rot out the wood. I was totally anal when it came to doing this just to make it last longer than it should. The head is another small issue. The holding tank is rather small but serves the purpose. If its original, the tank will be corroded on the bottom. It is mounted with welded in "L" brackets directly on a flat pad. It would help if it was spaced up with rubber bushings to avoid shock and contact from the pad. Gets really rough in the cabin while under way. You will find everything all over the cabin unless you use the factory net attached to the cabin bench seat. Towing: If it does not have a trailer, do not under spec. I personally went with a 14K capacity tri-axle. At least brakes on 2 axles. The more the merrier. To pull, I personally have a crew cab dually. At least a 2500 series truck..although a 3500 would be much better. Sorry if I'm rambling on here but it may give you some insight on what to look for. If you have any questions, pm/email me. I'll be a little hard to get ahold this week. Stan |
Re: 1990 Bullet
Stan,
Do you have a Bullet for sale? If so, please email me the specs and all the pics you have. Thanks! :) Clay Email: [email protected] |
Re: 1990 Bullet
What they said!! Bullets are GREAT boats and (IMHO) are the best 31 foot boat out there. They run like a much larger boat.....and you can have the big red 1 on your boat for short $$$. :cool: :cool: :drink: :drink:
Re: 1990 Bullet
Exactly, what they said. I had been told by a friend who had a variety of Cigs including that I wouldn't believe the ride. I had an offer on a Scarab at the time and he insisted that I ride in his Bullet first, claiming that it rode about as well as the Cafe except maybe in some extreme conditions. So hooked up with him for a ride and was amazed. At the time wife was suffering from a couple of cracked ribs, so was holding on for dear life at the first wake we crossed. Turns out we didn't even feel it, and you shold have seen the look on her face. So after a brief but great ride on a busy weekend here at LOTO, at the worst part of the lake I was sold. The other thing that impressed me is that they don't require the use of tabs, and come on plane quickly compared to other boats I've been in. If you can find one, don't think you can go wrong.
Good luck. John Sunrise Upholstery. BTW, pics of mine on my website |
Re: 1990 Bullet
I love mine
It is Birdog's old boat agree with evetything above! |
Re: 1990 Bullet
1 Attachment(s)
The Bullet is a great boat. The only difference in the ride is it can considered to be a wet boat at times(only the pass seat)The last time I checked I never ride in that seat! I have a friend of mine looking to sell his 88. The boat has 540 Bulldogs gaffrig gauages etc. on a trailer. Boat does 75mph and can be had for around $40k. Call him if you are interested
His name is Charlie 203-376-8457 |
Re: 1990 Bullet
probably a stupid question but what does the fifty fifty mean?
Re: 1990 Bullet
Re: 1990 Bullet
Originally Posted by OldSchool
Another word for marriage!! :D :D :evilb: :evilb:
My buddy and his dad bought the boat together new in 88, hence the name. |
Re: 1990 Bullet
2 Attachment(s)
4195 that a nice looking boat. For those of you that have Bullets can you post a pic of your boat? I really appreciate the pros and cons. I understand the issue with the delaminated and seperation of the wood, and pretty much anticipate the replacement issue upon purchase of an older boat like that. Does anyone else have any advisement for Bullets? There were 2 Bullets I saw here in the Classifieds. Does anyone know these boats?
Again post those Bullet pics.... http://www.offshoreonly.com/esvon/page-5977.html and http://www.offshoreonly.com/esvon/page-6270.html |
Re: 1990 Bullet
how does the bullet ride compared to the 30 vice or the other 30 footer they made in early 2000 (can't remember the name)?
Re: 1990 Bullet
The 1990 CIGARETTE Bullet Pro Series is a great looking boat, but... $70K for a 15 year-old boat? :(
I guees I could write off the interest as a house! :p |
Re: 1990 Bullet
1 Attachment(s)
Earlier this year I picked up my Bullet out of texas and I love it even though I experience all the challenges Stan indicated what to watch out for; upholstry rot and head issues. My vessel is now having some engine work done and I just can't wait to get it wet again.
Posted is my 1990 Platinium Series Bullet that should be back in the water at month end so I can post more updated pics with some new graphics installed prior to the engine taking a crap-Still love my 31Bullet. BTW,Stan has a nice Bullet for sale and if anyone is interested in a Bullet:put his boat on your shopping list even though if you may not like color or graphics, IMO that he has shored up most of the problems you could and will have for some time. You can spend the money you'll save on major repairs and put towards graphic change or color and plus you can use it for the remaining season. Check out some of stans past post to see how maticulus he is and what he has already updated. |
Re: 1990 Bullet
so who is stan? Is there any pics? $$? I havent made up my mind yet. As far as color, its just paint right??? Paint can be changed cant it?
Re: 1990 Bullet
I think I have his phone number if you would like to e-mail me. I am not sure if ad still active but was ebay item #456424672 Yes paint themes can be changed very easy-Paint or Vinyl ...BUT his (Stans) is very classic and original-I am sure he can send pics and you may not want to change. good luck |
Re: 1990 Bullet
1 Attachment(s)
I think this is cig1988 boat.
Also check out the 'bullet thread' http://www.offshoreonly.com/forums/s...5&page=1&pp=20 for more bullet info |
Re: 1990 Bullet
I have another one that will be coming up for sale shortly. Feel free to call for details I can fill you in it will be completely updated.
918-232-3503 |
Re: 1990 Bullet
Thanks Wyatt, Its still for sale and enjoying the hell out of our short lived season.
Re: 1990 Bullet
those were some nice pics. Thanks
Re: 1990 Bullet
waiting for the owner of the 89 Bullet to call. Im going to go look at it today if its not gone. Ought to be an exellant project boat if it passes inspection
Re: 1990 Bullet
cig 1988. could you send me a few pics of the one you have for sale?
Re: 1990 Bullet
Re: 1990 Bullet
Originally Posted by cig1988
Sent you an email. Stan
emailed you back |
| All times are GMT -5. The time now is 05:29 PM. |
