-   -   Speed From A 04 T/s Top Gun (https://www.offshoreonly.com/forums/cigarette/117167-speed-04-t-s-top-gun.html)
baja36ft 11-25-2005 04:38 PM
What Speed Do You Guys See With A 04 38 Top Gun
With 525's? We Have A Set Of 32 Bravo's On Now
Is That The Best Prop Or A 5 Blade? Thanks.
pm203 11-25-2005 04:44 PM
Re: Speed From A 04 T/s Top Gun
Average speed shoud be 85-86 ish.My friend has a one that does 90mph.It is a very light boat and without the extended cabin.
baja36ft 11-25-2005 04:45 PM
We Are Seeing 81/82 Did Not Know If This Is Right
Thought It Should Be More.
pm203 11-25-2005 04:48 PM
He is running 32 Labbed (.500 EFI boats run 81-82 all day long.)Your boat should be 2-3 MPH more at least.
lucky strike 11-25-2005 08:24 PM
I have a cousin who has a 2005 Top Gun with 32p 4 blade bravos. The best he has ever seen is 86mph and that was with the temp being 40 degrees and 2 people. Most of the summer he ran 84mph. He tried the Merc 5 blade prop and that didn't work at all. You should run 84-86mph.
I also have a friend who has a 2001 Top Gun with 500EFI and XR's with 28p 4 blades and is having a hard time breaking 80mph.
LS JR.
Tazz 11-25-2005 09:19 PM
My Freind has an 05 w/525's, it runs 87-88 in freshwater.
baja36ft 11-25-2005 09:24 PM
So What Is My Problem ?? We Are In Salt Water
At Wot We Can Only Get 4950rpm.
Tazz 11-25-2005 09:48 PM
81-82 in salt water is definately slow...somethings up.
Downtown42 11-25-2005 09:54 PM
prob is you need to be 5350 WOT...prop will solve I tink.
baja36ft 11-26-2005 07:24 AM
They Said The 32 Pitch Is The Right Prop For The Boat
So Thats Why I Am Asking .what Does Everyone Trim
To On This Boat?
BillR 11-26-2005 08:15 AM
My Freind has the last 05 built @ 188th st factory. w/525's, it runs 82ish in salt water.
my '02 w/ 575's runs 87 - 90 depending on variables.
pm203 11-26-2005 08:34 AM
Alot of these boats are not set up right from the factory. I would check and make sure the drives are aligned first.Do you have an extended cabin? That adds some weight.You should be turning 5200rpm @ wot. It took my friend in his last two 525 boats some time to get the right prop setup.
HMJudge 11-26-2005 09:31 AM
A 525 Gun with ITS and Sport Masters is 85/88 with a GOOD set of props.Call BK at Offshore or Bud at Cig they are the best with props.
lucky strike 11-26-2005 10:14 AM
I would call Phil @ Lip-Ship and ask him what to do. Tell him Lucky Strike told you to call. I wouldn't get that excited about getting much more speed becuase he says most 525 boats run 86mph and that is from the horse's mouth.
LS JR.
dreamer 11-26-2005 11:21 AM
To On This Boat?
good question
i go to 7 on my playboy
Downtown42 11-26-2005 12:28 PM
I stand corrected. My mistake. Mine are 5300 test report and 5350 trimmed up...stock...Reggie may have a connection there.
If you lab your props that you have now, you will get another 2-300 rpms and they may work. Not sure, call Throttle Up
Joe 12-14-2005 04:16 PM
Where are you on your trim at WOT?
I have an 03 Lipship w/ 525's. Tattle-tale GPS Speedo proves 89 on it. However, on Garmin 182, a little less than 2 MPH slower.
Phil swears on 4.5 on trim (I have an extended CG Cabin and TONS of extra weight in speakers/amps/batteries etc...).
Gotta love Lip-Ship!
P.S. Harry, did you ever sell your 42? We had a conversation about it appx. 6 months ago.
Joe
bcschoe 12-14-2005 04:48 PM
[I also have a friend who has a 2001 Top Gun with 500EFI and XR's with 28p 4 blades and is having a hard time breaking 80mph.
LS JR.[/QUOTE]
Not anymore...and I know there is more with some little tweaks...
