1991 Top Gun weight?
What does a 1991 TG weigh with a full tasnk and TRS drives?
Thanks, Im asking for a friend who has one and is looking into a lift. |
Re: 1991 Top Gun weight?
a 10,000 lb lift would not be enough when the boat has fuel and dont forget you coolers your coolers i would suggest 12,000 lb lift what kind of lift?
With full fuel and gear you will be over 12000 lbs and that is without any one in the boat!
I weighed mine, 1989 Top Gun, It was 11,300 lbs. 1/4 fuel, no people.
My old 1991 was a Carbon fiber boat & it was 9400 pounds
It belongs to Pool Whore on OSO and is for sale & it is like new. It has 525 Hawks & TRS drives. |
1 Attachment(s)
Mine is for 15000 lbs. I would not go any less.
Thanks Guys
Originally Posted by Blue by You
(Post 2016404)
Hey....a real world number!!! You could use a 12,000 lb lift, but only if you install airbags and a weight-distributing hitch!!:eek: :D In other words, He will need a 15K lift.;) :evilb: |
My 93 Kevlar and 97 Kevlar TGs sat on a floating 12K lift for several years and it did fine. If you want to be sure then 14-15K and you'll be fine
Originally Posted by Von Bongo
(Post 2017161)
| All times are GMT -5. The time now is 04:56 PM. |
