Did they make staggered Top Gun's in the 90's
Does anyone know of any staggered older model top guns. Pre- 98-99. I am interested in one. Prefer Bravo rigged or better, no power. I am getting the itch to upgrade.:D
Not many of them made ( less than 10 ? ), and I dont know of any that were rigged with Bravo's. Most of them produced are 1992 thru 1995's, I believe.
Anyone know of one rigged with anything?
Most of them are the "90 MPH EDITION" boats, and they get snatched up pretty quickly. They were rigged with 5's. If you do find one, you need to be ready to buy, and pay since I don't believe you'll find one needing much work.
Where'd FatBoy end up this time ???? Was at Phils ....
2 Attachment(s)
here's one
Originally Posted by cigracing1
(Post 2055349)
here's one
1 Attachment(s)
This one is at Cumberlan for sale no motors
(Post 2055362)
Is there a link? |
Jeff,
The Lock and Load boat is mine, now called Pure Pressure. From what I have found is they made 5 in the early nineties. Most are the 90 MPH edition. They were guarenteed by Cig to run 90 with 700 or so motors and weighed about 9500 lbs. I was searching long and hard for a 41 Apache or a 38 with number 3A, 5, or 6 drives. When I found mine at Phil's it was in rough shape. I had to redo about everything. Like Brandon said be ready to move and pay a little more than a regular Top Gun. One ride in the rough and you will understand. With the staggered engines you give up cockpit but gain engine access. The center of gravity is lower and the balance is awesome. I would not recommend Bravos on these or any Top Gun with any power over stock 525's. One is raced as Pollo Tropical, One is called Pure Adrenaline, one is Fat Boy, and the Last is the Spider boat?? Mine is different because of a real half cabin and it was rigged and built at TNT, not Cigarette. (they layed the hull up) Mine is also very heavy almost 12,500. I wasn't as concerned with top speed as I was ride in the rough. Any of them will turn heads anywhere you go. There are pics on the classic ride section if you are interested. Hope this helps, Carl |
3 Attachment(s)
here ya go Carl, Nykamp send me these...
| All times are GMT -5. The time now is 03:05 AM. |
